SRM Origin - Composite? Anybody owns it? Picture?
Hey guys.
Looking to buy a SRM origin. Looking at the Composite Version. Does anybody have a picture of it? Can you see the carbon weave or is plain carbon ud?
I can't jusity the THM version, thats just to much for a powermeter even thougt that looks the bomb.
/Thanks in advance!
/Thanks in advance!
- MrCurrieinahurry
- Moderator
Therez a couple on ebay (uk) right now with pics etc.
Ahh I see.. Is the only difference with LOOK that you can change the lenght of the arm? Looks like something that would become a sound problem in the future.
The composite is also over 100g heavier than Look arms since I think they're aluminum arms wrapped in carbon or something like that.
God damnit! Hmm kind of like the idea that I can use the original dura ace chainrings.. Maybe I should go thm crank with Carbon ti rings and Favero pedals....
or just buy a non-power THM and screw on some Favero's .... just sayin!
Had a couple Origins in LOOK flavor. Never had an issue with noise even with a lot of travel (taking the inserts in and out).
They will become wedged in pretty good but it's not really an issue. The THM version is what you want if you want the ascetic plus the lack of hassle of adjustability. But there is obviously a 500 USD up charge for it plus it's lighter.
There are a couple threads on the forum with pictures if you're still looking.
Just ride ..
Yes thought of that too. Had them before they are awesome.mashiehood wrote: ↑Sat Oct 01, 2022 9:53 pmor just buy a non-power THM and screw on some Favero's .... just sayin!
Just buy a rotor carbon crank and power2max 4sl spider. With the regular chainring they are 620gr complete (actual weight) And not much heavier then the thm srm combo with carbon arms (listed weight). Oh and at least half the priceNejmann wrote: ↑Sat Oct 01, 2022 2:30 pmHey guys.
/Thanks in advance!
I just think the rotor is a little unsexy? Does that combo take original dura ace chainrings?wickedstealthy wrote: ↑Sun Oct 02, 2022 9:32 amJust buy a rotor carbon crank and power2max 4sl spider. With the regular chainring they are 620gr complete (actual weight) And not much heavier then the thm srm combo with carbon arms (listed weight). Oh and at least half the priceNejmann wrote: ↑Sat Oct 01, 2022 2:30 pmHey guys.
/Thanks in advance!
Yes it can take the dura ace rings if you want. But I can't be bothered by those ugly rings.Nejmann wrote: ↑Sun Oct 02, 2022 12:45 pmI just think the rotor is a little unsexy? Does that combo take original dura ace chainrings?wickedstealthy wrote: ↑Sun Oct 02, 2022 9:32 amJust buy a rotor carbon crank and power2max 4sl spider. With the regular chainring they are 620gr complete (actual weight) And not much heavier then the thm srm combo with carbon arms (listed weight). Oh and at least half the priceNejmann wrote: ↑Sat Oct 01, 2022 2:30 pmHey guys.
/Thanks in advance!
I added the combo I run on my bike
