Light but upright-ish
I'm about to turn 40 and am losing a lot of flexibility despite my best efforts. My Izalco Max is pretty uncomfortable these days and I'm thinking of starting over with a bit more upright position - not as extreme as some of the Domane/Roubaix configs you see out there; somewhere in the middle.
I'm not srue what bike to look at as a starting point. I have an older Focus Paralane that I like the fit of OK (BB feels a smidge high), but I'd like to leave it as configured, around 20 lbs. The contemporary endurance bikes all seem to come with shock absorbtion tech I don't need that adds weight.
Any other bikes you'd recommend for longer rides and stiffer bodies? I'm otherwise a light weight person that does a lot of climbing and want to keep playing to those strengths through my bike configuration. Thanks
Canyon Endurace, Seka Exceed, Giant Defy, BMC Road machine
You're not necessarily stuck moving to an endurance bike. There are lightweight race bikes with significantly higher stack than the Izalco Max. Cervelo R5, Enve Melee, Cannondale Supersix Evo, Orbea Orca, to name a few (all in the 570-580mm stack range).
Cervelo soloist, orbea orca = basically 10-15mm bigger stack compared to race bikes. (Sorry, im comparing my size, 60cm). Still aggressive headtube angle and short trail.
Bmc Roadmachine (1st gen especially), Cannondale Synapse are both "sporty endurance" bikes, with no extra suspension parts. Not as aggressive as bikes above, but snappy for sure
My wifes Synapse Hi-Mod (link below) is probably under 7 kilos in size 56, without pedals with regular 45mm wheels after I got new barstem. No weightweenie components at all.
I would look not just into stack/reach, but also at angles and trail.
His: Orbea Orca OMX
- wheelsONfire
ax lightness vial evo disc
canyon endurance
canyon endurance
Bikes:
Open *UP* (2016.04.14)
Pinarello Dogma. With same reach is offering me 1.5cm more stack over my SL7! Needless to say that spacers on Dogma are built to look good. So having like 2.5cm spacers is ok!
On the other hand SuperSix Evo 2021 spacers are ugly and there is extremely low amount of cockpit combinations your can use on it (from the design perspective i mean)
SW SL8 RTP 56cm @ 9270 / CLX II / CS OSPW / CEMA BB
S Epic 8 L @ XX T-Type / Berg Ratheberg 30 / Quarq / Fox Transfer SL 100mm / 3p
You already have a light, upright bike in your stable. What's holding you back from dropping weight the Paralane? You can easily get that to 7.0kg. With my Hylix carbon post, Farsports Feders, Kalloy Uno stem, EXS Cycling carbon bar, I'm sitting at 7.0kg with Ultegra Di2. Change the heavy fork to an Enve unit, and you're below 6.8kg. If you have the older Paralane, it would be the lighter 930g frame.
- wheelsONfire
Something that you should consider, a race bike will ride different from an endurance bike.
An endurance bike probably would ride a bit more "friendly". You could also run your Paralane with a deeper drop stem.
A longer stem is a better idea using than a race bike with high row of spacers and short stem.
It could be a good idea to play around with stems to see where your perfect position would be before you go all in for a new bike.
If we had been neighbours you could have loaned stems from me. I think i have around 25 now.
Bikes:
If you are having issues handling significant drop as on your Izalco, I think it's a mistake to go halfway. Another racebike with slighly higher stack, might not satisfy. A couple of centimeters won't solve your issue.
As for your Paralane which you like, you will not find anything much lighter and as upright. It's a well loved bike by many. Just get another one and set it up aggressively, or some similar true endurance bike.
I've mentioned it before on this website, nothing is more racy, lighter, more comfortable, and more upright than a Parlee Altum. But I think the model may be discontinued. But that's a pure road bike as the tire limit is 28mm actual.
