- Comfortable clearance for a 34/35mm tyre, hence looking at a stated clearance of 35-38mm
- Option for internal cable routing
- Compatible with mechanical groupsets (currently running R9120 groupset, but may upgrade next year)
I'm also not averse to an Asian-direct frame option, but at first glance you're either looking at a 32mm max clearance, or a full-on gravel setup.
EDIT: Should also add, quite keen to stay off the beaten track. So not blown away by e.g. Aspero, Synapse or Domane
Any suggestions? Clearly being a WW forum, lighter is better!
