SR EPS 12s installed and the RD shifts perfectly from sprocket to sprocket accross the whole casette. One sprocket overshifts which rubs/ grates when you shift its the 13T (all the others are fine) which drives me nuts. I have checked the hangar - straight, tried to move the position of the sprocket using the RH shifter and the 0.2mm movements - this just moves the problem to the next sprocket, tried re zeroing... run out of ideas! Chain and cassette are not worn.
Anyone had anything similar?
Thanks
EPS 12s shift question....
had something similar on my Eps12 but hadn’t realised that on v4 Eps you can adjust the rear derailleur for just a single sprocket as well as making adjustments across the whole cassette. This solved my shifting but fingers crossed you can fix yours as well.
Coming from Eps11 I had assumed set up was the same so hadn’t realised this was an additional feature
1.10 on the video for reference for anyone else https://www.youtube.com/watch?v=MqzrWuuceNU
My guess is that you have to try your luck with resetting the whole cassette setting.
I had this problem with the monoblock 12s cassette Im using where I couldnt get rid of the same exact problem (with Campy cassette no problem) but with a good setup for the whole cassette it does work smoothly.
I have tried resetting the whole cassette - still get the issue on the 13T. The only thing I have not checked is whether the spacer between the 13T and 14T is broken - not quite sure what the sizing is as the cassette diagram shows it at 2.0mm but labels it as an F spacer which is 2.2mm??
