Challenge Criterium RS
LanceLegstrong
by LanceLegstrong
They are right about one thing: the only correct color for these tires is white, and they are beautiful.
Specialized Tarmac SL7
Specialized Crux
Velobuild 168
Trek Checkpoint ALR
TobinHatesYou
by TobinHatesYou
Erwin wrote:
Mon Mar 06, 2023 6:46 pm
Wet grip is still a problem with the new compound, but everything else looks quite good.
And BRR’s scale does not adequately enumerate how bad the wet grip is on Challenge tires. They are downright dangerous.
Yoln
by Yoln
TobinHatesYou wrote:
Tue Mar 07, 2023 11:14 am
Care to elaborate?
#RETIRED# Lynskey “the Do-it-all Helix” 🧬:https://tinyurl.com/bdmb5y24
LanceLegstrong
by LanceLegstrong
Anybody with a membership care to post the rolling resistance vs psi chart? Looks like less than a watt compared to GP5Ks at 100psi. Curious to see them at lower psi.
Specialized Crux
Velobuild 168
Trek Checkpoint ALR
Yoln
by Yoln
Basically identical RR to Michel Power Cup, and .7 to .9W higher than GP5k depending on the version at 80psi
LanceLegstrong
by LanceLegstrong
Not bad at all. Thanks.
Specialized Crux
Velobuild 168
Trek Checkpoint ALR
TobinHatesYou
by TobinHatesYou
Yoln wrote:
Wed Mar 08, 2023 9:26 pm
Care to elaborate?
There’s nothing elaborate about my comment. They have no wet grip in a practical riding sense.
RDY
by RDY
Depends on the road surface. On slick asphalt, yeah, they're lethal. But IMO no more so than similar tires. I.E. I've found the GK Slicks just as bad as Strada Bianca HTLR on smooth asphalt. On rougher tarmac they're certainly not class leading, but not dangerous either.
But the amount of time I ride on smooth asphalt, is very small, and smooth wet asphalt is close to nil.
Anyway once available in larger sizes, these should be my tire of choice for dry weather given the excellent RR at 60psi, and good puncture protection. Challenge say end of year / early next for the bigger sizes. I'd guess there will be a 30 and 33 if they conform to sizing in other tires.
TobinHatesYou
by TobinHatesYou
RDY wrote:
Thu Mar 09, 2023 10:18 am
Not my experience at all. With 40mm Strada Bianca Pros I went down instantly (slid out both tires) while taking a slow corner at about 25km/h with barely a lean and no brakes. Everyone else in my group made it around with no issues on regular narrow road bike tires. The road was damp and the surface was standard asphalt/bitumen.
Check the comment section here: https://www.bicyclerollingresistance.co ... r#comments
RDY
by RDY
Fat slicks are going to be much worse than narrow slicks in greasy or wet conditions. They aquaplane much more readily. That's what's happening when they slide.
Miller
by Miller
RDY wrote:
Thu Mar 09, 2023 11:36 am
We do not ever experience aquaplaning with bicycle tyres, our tyre pressures are too high and our speeds are too low. Assuming THY was running say 60psi, and using an equation given in wikipedia, he'd need to be travelling at 80mph/130kph before aquaplaning could occur.
So no aquaplaning and that's just physics (lol).
Lina
by Lina
I'd like to see any bicycle tire aquaplaning at 25 km/h. Reality is that it just doesn't happen at those speeds. Even on a full slick. Losing traction on wet doesn't mean that the tire is aquaplaning. It's aquaplaning when it can't displace all the standing water between the road surface and tire so that the tire is no longer in contact with the road.
RDY
by RDY
Ok, I'm using the term incorrectly. But adhesion is going to be minimal in wet, especially on a compound that has poor wet adhesion, so you're relying on deformation. If your tire pressure is just a little bit too much than the (wet) conditions demand on a fatter tire, then you're going to go down as they won't deform enough to grip. Even at too high pressure a narrow tire will still deform quite significantly at the contact patch, even if area of contact is small. My experience was that you had to run big GK Slicks and SBs way below normal pressure in the wet on smooth surfaces. If the surface is smooth it significantly reduces the deformation. I expect other fat slicks wouldn't be hugely better, unless they deform a lot more. I haven't found a similar need to run narrower slicks way below dry pressure in the wet even if their adhesive properties are better.
mathias720
by mathias720
i have been running the michelin powercup tlr untill now for road racing, but really looking forward to trying these as they seem to have way bette puncture protection, same rolling resistance, and a bit wider thread.
i really dont race in wet coniditions anyway.
ViperFFM
by ViperFFM
At this point I wonder if there ever will be a better tyre than the 5000 TL that Conti discontiniued because it was too good
carbonLORD wrote:
Fri Mar 12, 2021 12:23 am
I'm a CAT 3 Masters racer, not a dentist.
