HBike
by HBike on Wed Nov 30, 2022 9:36 am
TobinHatesYou wrote: ↑Wed Nov 30, 2022 8:32 am
HBike wrote: ↑Wed Nov 30, 2022 8:24 am
Scott Addict has 5mm mandatory spacer as far as I know, so .15cm less reach. For an 58 frame the SL7 and Addict RC are almost equal in stack then when including these, but STA is smaller for the Scott, so you sit >6mm further back than on the SL7, depending on saddle height.
Your saddle setback is your saddle setback. STA is only a problem if the combination of STA, seatpost and saddle do not meet your setback needs.
LOL. Similar to reach, using your sentence: Use a different stem. Reach is only a problem, if the combination of HDA, stem length and frame reach do not meet your needs.
I would have to use a different post, as Scott provides a 20mm setback option only for 56 and up, another 300 Euros. I don't want to move the saddle too far forward with carbon rails, being a larger and stronger rider than average and having to use bumpy roads from time to time. The Tarmac system weight isn't that large.
TobinHatesYou
by TobinHatesYou on Wed Nov 30, 2022 10:02 am
HBike wrote: ↑Wed Nov 30, 2022 9:36 am
The bars/stem are a control surface and the distance from the steering center matters. The saddle is a fixed point. It does not move.
If you don't want to buy the correct setback post for your fit, that's your problem. It doesn't mean you move your saddle to compensate.
HBike
by HBike on Wed Nov 30, 2022 10:52 am
TobinHatesYou wrote: ↑Wed Nov 30, 2022 10:02 am
Lame excuse in my opinion. I can apply your argument to the front, too.
BigBoyND
by BigBoyND on Wed Nov 30, 2022 11:59 am
HBike wrote: ↑Wed Nov 30, 2022 10:52 am
Tobin is right. A bike with long reach and a short stem will behave completely differently from a bike with short reach and long stem, for the same fit. Even if all other things are equal at the front.
But in the back, everything is fixed so there is no impact in any way whether you have the seat slid forward on a bike with slack STA vs slid back with a steel STA to reach the same final position.
Andrew69
by Andrew69 on Wed Nov 30, 2022 9:01 pm
People seem to think that they can buy any bike and adapt their position to fit the bike, when the truth is there is a very small "window" of fit that is ideal for each people based on their proportions, flexibility, etc
How many threads do you see of people asking for fit advice because they have numb hands, neck pain, knee issues, etc?
Far too many IMO
wheelsONfire
by wheelsONfire on Fri Dec 02, 2022 12:34 pm
These days i would guess either best price or availability is the thing? (or both)
Am i off saying i guess Scott is the easiest to get at a discount?
I'm still intrigued by S5
Bikes:
Open *UP* (2016.04.14)
George46GR
by George46GR on Fri Dec 02, 2022 5:27 pm
wheelsONfire wrote: ↑Fri Dec 02, 2022 12:34 pm
What if someone (me...) wants the stiffest bike he can have? (no flexing seatpost, super stiff bottom bracket area). The new Scott Foil or the new Cervelo S5 ? Thanks
2023 Cervelo S5, size 56, sapphire/ice
wheelsONfire
by wheelsONfire on Fri Dec 02, 2022 7:20 pm
George46GR wrote: ↑Fri Dec 02, 2022 5:27 pm
Not sure, but from what i have understood by reading, it would be S5.
Also, Scott uses PF86 (a standard which should be burried).
I would pick S5 and not look back.
Bikes:
FactoryMatt
by FactoryMatt on Sun Feb 19, 2023 5:26 am
parlee RZ7 lol. two-bolt aero seatpost. 1.25 inch steerer. carbon box stem. 35mm bars. im 85kg.
