Where you seeing good Canadian prices on Factor frames or builds?Conradsleight wrote: ↑Sun Sep 04, 2022 5:30 pmI think depends on where you live, at least here in Canada Factor is a better value than specialized and others.
New bike time - 2023 Scott Addict, 2023 Scott Foil, 2023 Tarmac SL7, 2022 Madone...thoughts?
Does it happen enyone to know about the new 2023 scott foil frameset availability in europe ? Thanks in advance.
2023 Cervelo S5, size 56, sapphire/ice
I just bought a 2022 foil! Madone didn't have enough Seatpost. Seems a pretty big blunder on treks part.
The foil, weirdly is more comfortable than my roubaix which is weird.
SL7 or Ostro. Both super confortable and amazing bikes. SL7 will be the most expensive with the best resale value. Factor will be the best value. In US it's cheaper than any of the bikes on your list I belive.
Tarmac SL8 Maganta Gold
Crux Green Pearl
Previous bikes:
Crux Forest Green
Tarmac SL7 Snake Eye
Venge Bora Team
Venge Purple
Trek Madone SLR 7
Crux Green Pearl
Previous bikes:
Crux Forest Green
Venge Bora Team
Venge Purple
Trek Madone SLR 7
even with the long seatpost ? There are 2 sizes
2024 BMC TeamMachine R
2018 BMC TImeMachine Road
2002 Moots Compact-SL
2023 Pivot E-Vault
2023 Pivot E-Vault
Yes that's correct the long Seatpost isn't actually that long for someone buying a 62 frame size.spdntrxi wrote: ↑Mon Nov 28, 2022 7:15 pmeven with the long seatpost ? There are 2 sizes
The SL7 has silly resale value in Europe. After a year of riding it I was offered 1k less than I paid for it new. So that's definitely something to consider, at least until the SL8 comes out.CasualRider wrote: ↑Mon Nov 28, 2022 6:15 pmSL7 or Ostro. Both super confortable and amazing bikes. SL7 will be the most expensive with the best resale value. Factor will be the best value. In US it's cheaper than any of the bikes on your list I belive.
I haven't ridden the other frames you mentioned, but I will add to what someone else mentioned that the SL7 is very compliant. On the upside it's comfortabe for 100+ miles, but I often find myself wishing it was a bit stiffer. I ride a few bikes so would like my carbon bike to be overly stiff, I don't need it pulling double duty as a comfortable bike. As a single bike solution for road it is excellent and I continue to be impressed by it. There's a reason they are so popular
Is the new 2023 Foil (PRO) available somewhere in Europe for immediate purchase ?
No one has spoken about geometry of the bikes in question vs the OP's current bike.
I know exactly zero about the geo of any bikes in a size 60/62, but I think it would be safe to assume that the geo of each bike still runs "true" to the smaller sizes in that the SL7 is going to be the longest/lowest with the Madone, Foil and Addict (which now share identical geo) around the same.
Can the OP actually ride a SL7 comfortably?
The difference between the Roubaix he currently rides and a SL7 is really night and day
Andrew69 wrote: ↑Wed Nov 30, 2022 1:08 amNo one has spoken about geometry of the bikes in question vs the OP's current bike.
The listed stack for the SL7 does not account for the obligate headset bearing cover, which adds 10mm to the stack height and reduces reach by 3mm.
Fair enoughTobinHatesYou wrote: ↑Wed Nov 30, 2022 1:18 amAndrew69 wrote: ↑Wed Nov 30, 2022 1:08 amNo one has spoken about geometry of the bikes in question vs the OP's current bike.
Just checked the Spec website for stack and reach of size 61 bikes
SL7 Stack: 602 Reach 411
Roubaix Stack: 665 Reach 398
Reach is no big deal, easy enough to sort, but a stack difference of 63mm is massive!
Foil/Addict is at 606 and 409 (longer and lower than the smaller sizes would have you believe)
Madone (62cm) is at 620 and 403, easily the closet to the OPs current bike
Personally, I cant stand the tower of spacers I see under the stem of the (very few) S-Works SL7's I see locally, and thats why a SL7 will never be under my butt (Im too damn old and inflexible to ride bent over that far, plus the price north of AU$20,000 is just plain stupid), but thats just me.
As everyone suggests, buy the bike that inspires (God I hate that word though) you to get out and ride
Scott Addict has 5mm mandatory spacer as far as I know, so .15cm less reach. For an 58 frame the SL7 and Addict RC are almost equal in stack then when including these, but STA is smaller for the Scott, so you sit >6mm further back than on the SL7, depending on saddle height.TobinHatesYou wrote: ↑Wed Nov 30, 2022 1:18 amAndrew69 wrote: ↑Wed Nov 30, 2022 1:08 amNo one has spoken about geometry of the bikes in question vs the OP's current bike.
Your saddle setback is your saddle setback. STA is only a problem if the combination of STA, seatpost and saddle do not meet your setback needs.HBike wrote: ↑Wed Nov 30, 2022 8:24 am
