What to do with an "accident" bike?
Need an advice.
Was enjoying a ride out yesterday, on the way home there is this crossroads I know well, there is no red light but cars can go from different directions.
I was on a main road and on a marked bicycle lane, I saw this car coming from the left so I must have already stopped pedalling (from probably about 35-37kmh).
I have many years of experience on motorbikes and I always look at drivers to see if they see me, and I generally ride defensively.
I saw the people in the car and the front passenger was looking in my directlion.
I first thought the car would turn to the left as most do but it continued straight.
Then I started braking, with the back wheel, which locked up, I am sliding and veering off to the right, in hope the driver stops (they were going very slow), thinking surely they see me now, will stop and I just pass in front of the car... but she did not and there was no avoiding collision, I crashed into the car (I think BMW X1 or X3) right in front of the front door.
A woman driver, 83 years old, together with a woman passenger of same or slightly younger age.
Accidents happen.
I was very very lucky, and I think my experience helped.
I did not damage any of my clothes.
I only got a small cut on the left hand big finger.
I did dislocate and, as it turned out after x-ray, cracked a bone in my right ring finger, now in a cast.
I hit the car with my left side chest, so pain in that area, but no broken ribs and no blue marks either.
My face may have connected with the hood as I have a little pain on the side of the jaw, but no blue marks either.
That's all for my damages; no scratches, no blue marks anywhere, just broken finger.
I must have been going pretty slow at the collision point, my Garmin did not fall out of the holder either.
My poor Tarmac Peter Sagan Superstar, on the other hand ...
Well, front wheel does not seem to have any damage, no scratches, no cracks as far as I can see with unarmed eye, spokes are tight, the wheel rotates true, tire did not deflate and one day after the accident still at full pressure (about 90psi).
As far as I can see not a scratch on the bike, not even on the quick releases front or back, nothing on the fork or frame, just a little scratch on the seat on the drive side, but probably because I put the bike down after the collision (I did not fall).
The chain fell off, I cannot get it back on now, but no scratches on rear derailleur and it seems to hang "true" when looking from the rear, I did not bend the hanger. OK, tiny scratch on rear derailleur, but that is because one of the people that stopped after checking the bike put it back on the asphalt on the drive side (two car drivers stopped, one turned out to be an ironman participant and avid cyclist and he trasported my bike to my house while I took a ride in emergency vehicle to the hospital).
The handlebar is broken on the left side, under the tape it desintegrated and hangs, both (duraace) shifters are displaced, left shifter has lost the big plate (the gear shifter), I guess I touched the car with the handlebar, car had two small dents on the front fender.
The big question is - is this bike salvageable?
I really like SL6 Tarmac, and I love this Sagan paintjob.
I planned to keep this bike till the end of time, even bought spare praxis rings.
Seems like I was not going that fast and there are no scratches or dents on the frame, surely it is strong enough to take a jolt, I mean, it carries my 90kg and I sometimes hit potholes without a second thought.
A friend of mine bought a C64 frame, it had a crack around seat post area, he fixed it and he rides that bike no problem.
Anyone here had a similar experience?
What is your view on this?
Accidents happen.
2021 Cube Litening C68x SL Red&Black
2018 S-Works Tarmac SL6 Superstar
So no cracks besides broken handlebar and shifters? Besides small scaraches on saddle and RD ?
Great time to upgrade bars to one-piece handlebar, since you know your stem length/angle/width, get new shifters with fresh hoods and bar tape and consider yourself lucky.
Stay safe!
Stay safe!
His: Orbea Orca OMX
Glad you're OK - that could have been much worse. I think I'd have a bike checked by a pro. Perhaps one of the carbon reparir companies can look at it (or even X-Ray it), or even the best mechanic at a LBS. Hopefully it's fine but I think for safety sake you should get a second set of eyes on it before you start bombing descents on that thing again.
It looks like you've gone a little too extreme on your aero-angling the hoods in look!
In all seriousness, glad you are OK, and that is one stunning bike, hopefully it's OK too.
2015 Wilier Zero.7 Rim - 6.37kg
2020 Trek Emonda SLR-7 Disc - 6.86kg
2023 Specialized SL7 - 7.18kg
I would dissasemble the front end, drop the fork out and inspect the steeerer tube and the headtube (no cracks around the bearing seats).
A full on inspection by a carbon specialist would be great, but it depends if you have someone in your area.
I had a crash a few years back where a car ran a stop sign and I t-boned into it. The bike had no visible damage but I chose to replace the front fork just to be on the safe side. I don't think there's any good advice here, other than to ask the insurance of the driver to cover a full replacement.
I crashed mine decently back in 2020 after someone took out my front wheel in a big gust of wind, did all the above to eyeball it. It took two disassemblies and some patience to find cracks on the underside of the bar (which I still couldn't break by trying to manually snap them). Some paint cracks on the fork but no damage elsewhere. However, in my head the bike isn't the same and I won't/can't descend on it like before. Anything under 70kph it's fine, but above that I don't enjoy it like I used to. As far as I'm concerned it's now a disposable race bike that will die in a crit some time, but I don't have a replacement for it just yet. So my advice is keep it and accept it will prob be different (actual or perception), or sell it with full disclosure and sleep well at night.
Glad yore safe and in one piece! Straighten the wheel, straighten the hoods, go ride. @Terptay's suggestion of inspecting a few things isn't a bad idea either.
Canyon Aeroad CFR Di2 | Canyon Ultimate SLX 9.0 Di2 | Trek Domane SL5 Disc (Gravel Bike / Fly-Away Road Bike) | Orbea Tera H-30 Disc (Touring Bike)
I had exactly the same type of crash three years ago. Needed to replace the handlebars, rest is still fine. However, I am pretty sure the fork took most of the energy and this is the part (especially the steerer tube) that I would examine super close.
Other option is to go to an authorized retailer and ask them for a written certificate that this bike is good to use - of course they will not do it. Based on this you can probably get a full refund from the driver's insurance.
Fuji Cross 1.5 - Shimano 105 5800 | Cinelli Superstar Disc - Record 12s | Custom steel Karamba - Ekar 13s
I hit an illegally turning SUV at 16 mph in 2014, it threw me in the air and I tore a shoulder muscle on landing. The fork was completely sheered off and unusable, and to be safe I threw away the frame too. But I salvaged all the other parts including the front wheel that had absorbed the hit, so it is very do-able to save parts of your bike. My handlebars and shifters looked much like yours.gorkypl wrote: ↑Tue Aug 16, 2022 10:45 pmI had exactly the same type of crash three years ago. Needed to replace the handlebars, rest is still fine. However, I am pretty sure the fork took most of the energy and this is the part (especially the steerer tube) that I would examine super close.
Cannondale Supersixevo 4 (7.05 kg)
Retired: Chapter2, Tarmac SWorks SL6, Orbea, Dogma F8\F10, LOW, Wilier, Ridley Noah, Cervelo R3\R5\S2\Aspero, Time Fluidity, Lapierre Pulsium, Cyfac, Felt, Klein, Cannondale pre-CAAD aluminum
