Red DUB is the way to go, imo. Even lighter than EC90SL and Aldhu Carbon, and it's cheaper. My Red DUB 170mm arms with Quarq Dzero weighs 464g.
Spider Based Power Meter for Shimano 12sp
can you show us pics with mounted DA chainrings
Current Rides:
2023 Tarmac SL7 Di2 9270
ex 2019 S-works SL6
ex 2018 Trek Madone SLR Disc
ex 2016 Giant TCRAdvanced Sl
ex 2012 Trek Madone7
ex 2019 S-works SL6
I'm not sure if Quarq is the lighest option now. I had a DFour (30mm axle) with 50/34 rings that weighed 723g complete with battery. This is with the light version of the carbon arms (170mm). Below is the P2M weight as a comparison.
P2M NGeco 110-4SL 125g.
Rotor carbon arms 170mm with preload adjuster 249g.
30mm axle 95g
Chainrings and bolts (50/34) 132g
Total: 601g
The NG 110-4SL is even lighter at 118g.
30mm axle 95g
Total: 601g
With what arms did you get 723g? Def not "the light ones." With the Red or Quarq D1 arms it's 464g. 602g with Praxis rings and bolts.pdlpsher1 wrote: ↑Sun Aug 14, 2022 7:27 pmI'm not sure if Quarq is the lighest option now. I had a DFour (30mm axle) with 50/34 rings that weighed 723g complete with battery. This is with the light version of the carbon arms (170mm). Below is the P2M weight as a comparison.
30mm axle 95g
Total: 601g
But honestly, I'd get the P2M SL if the goal is to use Shimano rings. P2M gets a great reputation for durability and it's made in Germany (a place I don't mind sending my money).
I have P2M NGeco's on both my road bike and MTB. 2.5 years on the road bike, 7 months on the MTB. Road bike has 24mm ALdhu cranks and MTB has the stock SLX cranks that came with the bike. Never had an issue with either. The worst I can say about them is the OEM battery on the MTB only lasted 6 months. Usually change them once a year. Who knows how long it sat on the vendor shelf before I bought it.
I no longer have the PM. I bought it new in 2017 as a PM package. So I assume it's the light arms. I'm under the impression that Quarq started using the heavier arms last year. Also, my PM is the DFour not the DFour1. I'm not sure if that makes a difference or not. I don't think 30mm vs. DUB makes a huge difference. I loved my Quarq. I have had two and without any issues. I was merely pointing out there's another lightweight option out there. I've moved onto using GRX cranks and I'll be getting the new P2M GRX PM.BigBoyND wrote: ↑Sun Aug 14, 2022 8:34 pmWith what arms did you get 723g? Def not "the light ones." With the Red or Quarq D1 arms it's 464g. 602g with Praxis rings and bolts.
I'm running a Rotor Aldhu Carbon with a P2M NG eco 4SL with 9200. Nice lightweight option and P2M is always faultless (I've also got a Type S (5 years and counting) and another NG Eco).
You can run Shim chainrings on the 4SL and the Aldhu comes in a 24mm version.
Weight for the whole crank (175mm), functional Pm and
50/34 rings is 651g.
The native Shimano is 685g without PM, and 745g with PM.
The price when I ordered the Quarq was just too good.
The same scratched crank later went on the TT bike (had been on my gravel bike for 2 years):
The not so cheap option:
Don't know exactly but easily sub 600g on the entire system, with 52/36 rings.
The Quarq is definitely my go zo option. Light, easy to install, cheap, and has never once let me down. GPLama also regards it as the most reliable system next to the Assioma duo pedals.
Cervelo P5 Disc (2021) 9.1kg
S-Works SL8 (2023) 6.3kg
I just don't want the OP to think with light arms it's 724g, if they buy this setup. 30mm (GXP) is 60g heavier than DUB for Red level. Force GXP, which Quarq switched to a few years ago and is also carbon, is 160g heavier than Red DUB.pdlpsher1 wrote: ↑Sun Aug 14, 2022 10:05 pmI no longer have the PM. I bought it new in 2017 as a PM package. So I assume it's the light arms. I'm under the impression that Quarq started using the heavier arms last year. Also, my PM is the DFour not the DFour1. I'm not sure if that makes a difference or not. I don't think 30mm vs. DUB makes a huge difference. I loved my Quarq. I have had two and without any issues. I was merely pointing out there's another lightweight option out there. I've moved onto using GRX cranks and I'll be getting the new P2M GRX PM.
Would not wait on that. DC already said that the data of his test sample is inaccurate and he is in contact with Shimano about the data. Would be a miracle if GP Lamas is any better.
I don't see anything positive for the Shimano PM: not the price, the weight or the quality of the PM. I am still baffled that they did not just use the Pioneer tech and be done with their problems.
Ray's test model was, I believe, a pre-production model and was procured almost a year ago. GP Lama just bought a production model a few weeks back. A lot can change in the tech in 10 months.henau212 wrote: ↑Mon Aug 15, 2022 8:25 amWould not wait on that. DC already said that the data of his test sample is inaccurate and he is in contact with Shimano about the data. Would be a miracle if GP Lamas is any better.
I know Ray mentioned that he has a new DA PM in for testing but I haven't seen him mention any results on this unit. I am looking forward to reading his feedback and hearing from GP Lama before reaching a final conclusion on Shimano's new units. I hope they can get them sorted.
https://www.dcrainmaker.com/2022/07/the ... rance.htmlBdaGhisallo wrote: ↑Mon Aug 15, 2022 11:40 amRay's test model was, I believe, a pre-production model and was procured almost a year ago. GP Lama just bought a production model a few weeks back. A lot can change in the tech in 10 months.henau212 wrote: ↑Mon Aug 15, 2022 8:25 amWould not wait on that. DC already said that the data of his test sample is inaccurate and he is in contact with Shimano about the data. Would be a miracle if GP Lamas is any better.
See comment 9 forward. That thing he is testing is not pre production.
