I think pretty much everyone is aware of this but the interesting part is trying to figure out what kind of real world gains are up for grabs...
Weight weenies vs watt weenies...
I'm sure GCN does this kind of testing a few times already...V3Rs wrote:Would this work?
Get a C-40 with a watt meter and have it be in a good state of tune up with properly inflated tires. Ride at some reasonable output say 300 watts
with no wind. Record speed and compare to an S-5.
Sent from my Pixel 6 using Tapatalk
I didn't mind this either.
https://youtu.be/VHsLMCTkFso
Not super controlled, but they made some attempt at keeping it consistent by using the same power, bike, rider, position and tyres.
Hi. Do you have specific examples on the type of disagreement you have been hearing?V3Rs wrote:Wow- so why do some disagree with GCN's conclusions?
I’m happy to type up a storm and explain the nuances, but there is just so much that I feel a targeted step by step approach is more conducive.
In general: I believe disagreements occur because lots of people do not understand aerodynamics.
For one: It must be measured as a system. NOT individual modular parts and “added together” like weight. I would not be surprised if some people disagreed with me here, and while there are exceptions…. For most practical cases if they are stuck here, then we are all gonna be in for a bad time.
Two: It’s often counterintuitive. Something that “looks” aero might not actually BE aero.
Three: The average Joe/Jane cannot easily measure it, let alone see it. Thus, most only have a theoretical understanding of it with no practical hands on experience on quantifying aero gains. Then they argue like they are right, based on this incomplete understanding. Bad times.
Anyway those are some guess as to why people disagree.
If you squint, the fourth takeaway is that with aero, one solution that works for you, might not actually work for someone else. Or anybody else.
The process to get the most aerodynamic for you is VERY individual. But if people think one aerodynamic helmet or aero bike that posts the best result in a marketing article is actually the fastest for everyone, again, we are all gonna be in for a bad time.
So an "average joe", who doesn't understand aero, is totally fine (and possibly should) to put aero at a lower priority when deciding which bike to buy. It's b'cos...
normal person can't judge how aero a bike is in real world, and it's personal so the other's saying (including mfg's info) is likely not applicable, plus when one is to change wheels or components, all aero things would change (as a system consideration).
most of these responses have nothing to do with the question. maxim's explanation as to what is the fault with the gcn "test" is off target... sorry
If someone were to state why those tests yield incorrect results for THAT study, then fine... the rest is off target chatter...
They didn't test at yaw. Which is where most of the wheel and frame gains are over the old equipment.V3Rs wrote: ↑Fri Aug 12, 2022 1:12 pmmost of these responses have nothing to do with the question. maxim's explanation as to what is the fault with the gcn "test" is off target... sorry
They quote some much bigger gains here for things like skinsuit and helmet.
https://www.youtube.com/watch?v=hd0fXhDkH84
