EXS Aerover Cockpit
I ordered mine from Ali instead of direct and it came quickly...no nice retail packaging though.
360x140mm compact = 306g (w/o top cap and 1-1/8" shim.)
The lateral flex in the drops is pretty noticeable however. Unsure of whether this will be an actual problem for me on the bike.
Interesting,
On the farsport f1, the flex is very clear in the hoods (more torsion stress) and not so present on the drops (more subject to flexion than torsion)… the beauty of carbon anisotropy.
We are in subjective territory but it puts in perspective the « stiffness data » few Chinese brands present (recall the EXs was presented as stiffer than the vision 5d).
Nevertheless, it’s a very interesting bar, from geometry stand point!
I can't speak about the compact one but my traditional one does have lateral flex around the drops. In EXS test protocal, they didn't test lateral stiffness. Neither did FWB test lateral stiffness.C36 wrote: ↑Tue Feb 28, 2023 2:41 pmInteresting,
So far among the aero bar I've used, 3T aeroflux is the most stiff one regarding the lateral direction around the drops due to their dimension. The od of EXS drops is around 23.5mm, while that of 3T drops is around 24mm, but the thickness is identical, though EXS has a much smoother and cleaner inside. Simple physics as 3T od is at the limit of the hoods clamp to offer the stiffness....
I guess we should also clarify that the drops themselves are probably fairly stiff. The flex/deflection is primarily occurring at the elbow of the tops.
Effectively I can squeeze each drop over 1mm inward. The flex is not in the drops themselves…the tops are bowing.
Does anyone know when these compact handlebars will be available?
Can't they also be bought somewhere other than the official website?
The seller wrote to me that they will probably be available sometime after the summer holidays.
I would need them in the size of 380 x 110 mm.
Thank you very much. Mark.
MarkH14 wrote: ↑Mon Mar 06, 2023 10:04 amDoes anyone know when these compact handlebars will be available?
I bought mine from AliExpress with no delays other than confirming which headset cover I wanted included.
Got a link to the Aliexpress site? Can't seem to find them when I search. Thanks!TobinHatesYou wrote: ↑Mon Mar 06, 2023 11:08 amMarkH14 wrote: ↑Mon Mar 06, 2023 10:04 amDoes anyone know when these compact handlebars will be available?
https://www.aliexpress.us/item/3256804980300213.html
Unfortunately it looks like they bumped the price by US$100 since I bought mine.
- MrCurrieinahurry
- Moderator
Are these genuine exs products btw? Not implying they are not just wondering as AliExpress is known for fakes.
Basso Diamante eps 12
Nice looking bar, but... £425.... is not miles off from where you'd expect to see Trek or Specialized to price their wares. Getting pricey.
They are genuine. So far there is no copy of farsports products and EXS products in China.MrCurrieinahurry wrote: ↑Mon Mar 06, 2023 3:59 pmAre these genuine exs products btw? Not implying they are not just wondering as AliExpress is known for fakes.
That price is already really high on Aliexpress!TobinHatesYou wrote: ↑Mon Mar 06, 2023 3:02 pm
Unfortunately, it doesn't even offer the 380/110 combination I need.
I'm looking at getting the EXS because I'm still waiting for my new Trek bar since the recall. It's scheduled to arrive in May, which is a bit late. The EXS bar would also be 380 instead of 400, with the hope of some aero gains. The price is holding me back though, especially as I'll end up with the Trek bar eventually.
