Elilee XXE Crankset
StiffWeenies
by StiffWeenies
Elilee X-Novanta carbon axle crank weights
StiffWeenies
by StiffWeenies
Pyotrump wrote:
Fri Jan 06, 2023 4:23 pm
isehk wrote:
Tue Jan 03, 2023 1:22 pm
Pyotrump wrote:
Mon Jan 02, 2023 7:22 am
isehk wrote:
Sat Nov 26, 2022 12:59 pm
My pedals is favero assioma with xpedo thrust sl body. The offset is so high so I have no heel clearance problem.
But the crank are not straight. It bend a bit
I also have thrust sl and assioma. How did you deal with the increased Q factor?
I just adjust the cleats on my shoes....that's enough...
Wuhuh.. I measured the difference and it was almost 4.5mm. Thanks anyway.
Is the Q-factor on a Favero modded Xpedo not the same as regular Assiomas?
RDY
by RDY
StiffWeenies wrote:
Sun Jan 08, 2023 7:34 pm
That's pretty damned light. But if they get the first gen of carbon axles right I'll be amazed.
C36
by C36
What are those? prototypes? pre-production? production?
StiffWeenies
by StiffWeenies
C36 wrote:
Sun Jan 08, 2023 10:40 pm
You can pre-order them now. 4860RMB sans-PM, 7060RMB Sigeyi PM, 6760RMB XCadey PM and 7860RMB P2M SL PM.
RDY
by RDY
MrStop wrote:
Mon Jan 02, 2023 5:01 pm
This crank seems a bit hard to find, although I did find a listing on Aliexpress https://www.aliexpress.us/item/32568048 ... _shipto=US. The price appears a bit high when you can pick up a Sram Red dub crank for similar.
Elilee have already shut their AliExpress storefront ... after it only existing for a couple of weeks
MrStop
by MrStop
StiffWeenies wrote:
Mon Jan 09, 2023 5:02 pm
Where are you finding these?
StiffWeenies
by StiffWeenies
MrStop wrote:
Mon Jan 09, 2023 9:47 pm
Dealers in China are quoting these numbers
International pricing should be a bit higher
Pyotrump
by Pyotrump
StiffWeenies wrote:
Sun Jan 08, 2023 7:45 pm
Sorry for stealing this thread.. but answer will be short.
Assioma PM axle + Xpedo Thrust road pedal body == increase in Q factor 4.6mm.
So If you are using DUO, then there will be a humongous 9mm.
You can refer to this: viewtopic.php?f=3&t=148289&start=915 take a look at an user "Dooglehead".
StiffWeenies
by StiffWeenies
Pyotrump wrote:
Tue Jan 10, 2023 4:09 am
What a shame. That was my dream combo for a PM Keo pedal. The Exakt pedal body is ancient at this point and Garmin can't be made lighter.
At least the Q-factor isn't as crazy as DUO-Shi
wheelsONfire
by wheelsONfire
So for the rest outside Asia, Vaporware!
I can just imagine having one of these small brand cranks, having a bolt with damaged threads or anything really, you probably have a piece junk laying around.
Buying Sram, Easton yada yada it's an easy fix.
Bikes:
Open *UP* (2016.04.14)
Maddie
by Maddie
Yes, yadayada. You mentioned about 20 times that exclusive parts from the far east can be difficult to deal with in case of trouble. But guess what, people that are interested in parts from EXS, Elilee etc are aware of that. Not necessary to mention it every single time
hansotto089
by hansotto089
Yada yada - will there ever be a 175 version?
MagicShite
by MagicShite
wheelsONfire wrote:
Tue Jan 10, 2023 7:17 pm
The world doesn't revolve around the western parts of the world. GTFO with this narcissistic behavior of yours.
It's just incredibly sad sour grapes at this point. Please just stick to the topic instead of ranting about things that you're too envious about.
Hexsense
by Hexsense
Sorry that you are the minority.
World population include 7.88 billion people.
More than half of that are Asian (4.561 billion). Among those, 1.42 billions are Chinese and 1.40 billions are Indian. Then there are still many more populous countries in Asia.
So, if it's available in Asia, it's available for more than half of the global demographic. It just happen to not include your local area.
