Enve Melee
The general all-things Road forum!
hansotto089
by hansotto089
Does the Melee have enough space on the NDS crank to accomodate a 4iiii Powermeter?
reodl
by reodl
I have the latest 4iiii on my NDS 172.5 dura ace crank.
bretthopper
by bretthopper
Just got an Aegean blue Melee and its it looks even better in person.
Groupset: Ultegra Di2 (170mm cranks, 52/36T, 11/34)
Saddle: Specialized power comp (probably 200-250g)
Handlebars: Enve 42cm SES AR (with Enve computer mount)
Stem: 110mm aero inroute
Seatpost: biggest one?
Weighed in at 7.3kg without cages or pedals
Bb13
by Bb13
Nice what wheels ?
RockC
by RockC
Has anyone discovered any other routed bar/stem combos (and/or 3d printed top cap adapters) to run non-enve bar/stems? Ended up with a sweet deal on a Fray but dying at the cost of the cockpit.. Just curious if any other decent routes out there?
pmprego
by pmprego
RockC wrote:
Fri Jan 03, 2025 1:14 am
The fray is non-proprietary. Don't know about the top cap adapters but you can even run cables outside the bar/stem.
Was that deal with a bikeshop/enve seller?
DoesMyBikeLookFat
by DoesMyBikeLookFat
That exposes the top bearing and headtube to water/dirt ingress though, doesn't it? I've been hunting around for a low-stack 3D printed dust cover that would allow the usage of a Tarmac stem with In-Route headsets to avoid that and come up wanting. It's wild that Enve doesn't offer anything other than the -6º stem to the public -- none of their bikes have aggressive S:R
pmprego
by pmprego
DoesMyBikeLookFat wrote:
Fri Jan 03, 2025 3:33 pm
I think I saw photo of it somewhere. Couldn't find it now. But in my head it had two holes for the brake cables. It is provided by enve. It's a specific spacer to allow the cables to run outside.
One can even try to use some rubber around it to close even further ay gap.
But the outside cables has that negative aspect, for sure.
jayjay
by jayjay
pmprego wrote:
Fri Jan 03, 2025 4:30 pm
The Enve "bypass" spacer is included with the stem / stem-handlebar-combo
jayjay
by jayjay
It is -7° :D
DoesMyBikeLookFat
Oooh that's helpful, thank you!
pmprego
by pmprego
jayjay wrote:
Fri Jan 03, 2025 5:59 pm
My preferred setup in this photo
bretthopper
by bretthopper
Bb13 wrote:
Tue Dec 10, 2024 6:12 pm
Nice what wheels ?
Light Bicycle AR36 disc which are around ~1350g I think. Though I'm likely going to buy their new 50mm deep Turbo ones.
