Hi everyone
I am 182cm with an inseam of 93 (yes daddy long legs!)
I have relatively long arms and feet aswell.
I am riding a size 56 Pinarello F12 at the moment. I run the MoST 130mm stem with 38cm bars.
My seat height is maxxed out at 82.5cm (that is the minimum insertion line maximum has been reached) on a 0 offset post.
I would like to go up another 5mm or so but thats untenable given the current seat situation.
I cant go up a frame size as the stack becomes too high. The new F also has a lower seat post length meaning its unlikely the newer model can go higher
A 58 on most brands is just too big a bike for me on the front end
Does anyone know the maximum seat height I can achieve on a SWORKS SL7 or BMC SLR01 in a size 56?
Going off online measurements from the sites I doubt I could get either bike to get to 83cm.
Any help would be appreciated
Max Seat Height SWORKS BMC
I ride a 56cm Tarmac Sl7 with a seatpost height of 825mm. Even at that height I can go up 3-4cm before reaching the max saddle height.
Thanks to both for your replies
some bikes have different seatpost lengths depending on frame size too.. Although usually only the smallest 2 frames get a short seatpost.
2024 BMC TeamMachine R Building
2018 BMC TImeMachine Road
2002 Moots Compact-SL- getting aero look makeover
2023 Pivot E-Vault - completed project, full Xplr package
