Treptay
by Treptay on Tue Jun 28, 2022 10:21 pm
darrydonds wrote: ↑Mon Jun 27, 2022 8:52 pm
FIJIGabe wrote: ↑Mon Jun 27, 2022 2:32 pm
Another simple solution would be to grease the threads of the pedal. I've had that happen to me (more ticking than creaking).
Incidentally, I have been hearing "ticking" on my new SPD pedals. I thought I didn't tighten them enough to the crank arms. So I did. But then, after a while it started happening again (only when apply more power, like on steep climbs). So, I removed them and greased the hell out of them. Hope that fixes it.
yes, mine do that too (PD-ES600)
I think you could fix it with adding a litle bit of bearing preload, still need to try it though
darrydonds
by darrydonds on Wed Jun 29, 2022 9:33 pm
Treptay wrote: ↑Tue Jun 28, 2022 10:21 pm
PD-ES600 is what I have!
charirider
by charirider on Thu Jun 30, 2022 2:25 am
ipenguinking wrote: ↑Fri Jun 24, 2022 11:51 pm
Yes I always clip out DS pedal before stopping. I just cleaned the pedal and applied some Speedplay pedal lube I have handy. It has been over a decade since I gave up Speedplay for Time RSX. Then I switched to SPD-SL mainly because I dislike those fast wearing and expensive Time cleats.
Same here, switched to Time iCLick from Shimano SPD, no creaking issues whatsoever! Also much easier to clip-in, more stable platform etc etc; the only downside is walking much more uncinvinient so much so I need to carry spare pair of light sandals for walking around
2018 Cannondale SuperSix EVO 2 rim size 56 (raw stripped) 6.8kg
2014 Bridgestone Anchor CX6 Equipe size 55 (cyclocross) 9.6kg
Treptay
by Treptay on Thu Jun 30, 2022 8:35 am
darrydonds wrote: ↑Wed Jun 29, 2022 9:33 pm
Did you manage to fix yours? I find that adding preload means that they won't spin freely, and cliping in is then a problem.
smokva
by smokva on Thu Jun 30, 2022 1:49 pm
Treptay wrote: ↑Thu Jun 30, 2022 8:35 am
If you grease and adjust cone properly they'll spin freely, wont have any play and wont click.
darrydonds
by darrydonds on Thu Jun 30, 2022 7:36 pm
The extra grease does seem to do the trick (knock on wood) based on the last couple of rides. I didn't even thread the pedals to the crank arms as tight as before. What I also did a bit differently this time was wipe some grease off the threads on crank arms to remove any dirt or what not. Don't know if that made a difference.
pdlpsher1
by pdlpsher1 on Thu Jun 30, 2022 10:02 pm
If you hear ticks and creaks coming from the pedals, it's really your BB and not the pedals. Shimano pedals/cleats don't tick or creak. They are maintenance free, unlike many other clipless pedals.
Treptay
by Treptay on Fri Jul 01, 2022 8:34 am
pdlpsher1 wrote: ↑Thu Jun 30, 2022 10:02 pm
Maintenance free? Not really sure about that, since they sell you a tool for some of the pedals, to open them. Regreasing should be done sometimes, but not that often. And I have another set of cheaper spd pedals that used to tick /more like clank, but it went away after sometime. My bottom bracket is fine, because it just happens with these one pedals now. Also, I find all the pedals have a little bit of play in the bearings out of the box, am I the only one?
smokva
by smokva on Fri Jul 01, 2022 9:25 am
Treptay wrote: ↑Fri Jul 01, 2022 8:34 am
It's normal that cones need to be tightened some time after greasing when the grease "settles" down. It always happenes to me with campagnolo cup and cone hubs, after few houndred km i need to tigthen cone for ~1/8 turn.
ipenguinking
by ipenguinking on Fri Jul 01, 2022 3:05 pm
I installed new blue cleats on my regular Raphael shoes and did my regular interval drill yesterday. There was no creak nor grind. I can feel the shoe/pedal interface is really tight yet smooth. I'm glad that the problem is solved
darrydonds
by darrydonds on Wed Jul 06, 2022 7:59 am
I wish people just refrain from making blanket statement like this, based on very little information and context of the specific cases (not to mention the false assumption, i.e. "maintenance-free"). In my case, the ticking only started after I installed the new pedals. (I know a friend who also experienced SPD pedal ticking after a while and he fixed it by re-installing the pedals.)
robbosmans
- Moderator
by robbosmans on Thu Jul 07, 2022 4:22 pm
Yeah but the pedal itself won’t ever creak, its the metal on metal contact from the crank/pedal thread. Almost always down to no grease or dirty threads.
