Looking for a new bike/frame to replace my SL5 Disc. I'm tall/heavy rider with XL/60-61 frame: won't be chasing grams, but going after stable and fast bike.
-Want to be able to run Enve 4.5AR (or similar) with 32c measured tires for extra comfort. I'll stick with 28-30c tires that will end up being 31-32c
-Will use SRAM AXS with Dub crankset. Prefet not to have any compromises in bottom bracket. T47 is preffered. PF30/OSBB are ok. but no BB86
-I'd like to have all cables integrated. Having barstem combo is also good option, especially if I can run cables neatly.
-Extra points for small bag/storage: either "bento box" on top of frame (BMC RM01, Cervelo) or some in-frame storage (like on BMC Timemachine Road, Orbea Orca aero or Roubaix) but there're only few bikes that have it.
-I'm not the most flexible person, so not looking for a full blown aero bike. I prefer not to have tons of spacers. Currently have 1cm on top of SL5 Tarmac.
Current Tarmac is on CLX40 wheels (17mm internal) and before I had Allez Spring on CLX64. Besides Allez being alu bike, I liked it a bit better for planted feel. Hard to tell where it came from: stiffer frame, stem or bigger/wider wheels.
From what is seems, Tarmac SL7 is one of the best options out there, as it have everything inlcuding T47 bottom bracket minus top tube mounts.
Are there any bikes that come close to that and use threaded BB?
What my options are if we exclude threaded BB, but stick with "bigger" bottom bracket: BB30/PF30/386EVO
So far I found only a few bikes that match all the criterias:
Current Tarmac SL5, Stack/reach: 612/408, with 1cm (I think) spacer.
- Tarmac SL7: 602/411: BSA BB, nice integration (stem + bar). Seems too popular, other than that clears all the requirements. That's non S-works frame
Chaper2 Toa: 602/399, T47 bracket, got integrated handlebar.
Parlee RZ7: 600/409. PF30 BB, oversized stem with limited adjustability: +-1cm only. Pretty rare and seems comfy.
Orbea Orca OMX: 616/404: 386EVO BB. Lots of cool paint options.
Madone: 601/399: T47 BB, integraged bar. Less tire clearance, but seems that it can do 30cm measured.
Cannondale Supersix: 614/406: BB30, heavy integrated bar.
Parlee looks most exotic and aero and most premium. Should I even consider the rest if I can get one?
Chapter2 hits all the boxes,have T47 and comes with barstem.
Orbea and Tarmac looks like every other bike on the market. It seems that for the same price, I should go with Orca OMX (aka Hi-mod/S-works) vs standart Tarmac.
Any thoughts?
