3D Printed Saddles - future or fad
Eterna7m
by Eterna7m
tommyboyo wrote:They are amazingly comfortable, but do change the 'feel' with the bike slightly on the road. God send after 5+ hours, but not a big deal on shorter rides. Can see them being a game changer on rough terrain though.
Speaking as someone who has put a fair bit of time on the original power mirror and now Romin mirror and coming off years of using a Romin Evo mixed in with a Toupe and Power Arc for a bit.
What did make you switch to the romin and are you happy now?
tommyboyo
by tommyboyo
Eterna7m wrote:
Wed Jun 08, 2022 8:45 pm
Well Romin Evo was my saddle of choice for many years, so I had to try the mirror version.
I currently have a mirror on one bike and and a basic SW on another. I actually prefer the latter for short sharp rides, but the mirror for longer days.
spartacus
by spartacus
Lina wrote:
Wed Jun 08, 2022 6:21 pm
spartacus wrote:
Wed Jun 08, 2022 4:35 pm
Lina wrote:
Wed Jun 08, 2022 12:59 pm
The only way I see 3D printed saddles being better in a truly revolutionary way is if they make it for you. Instead of just making what are essentially normal saddles that are all the same, just done with 3D printing.
They're not the same as normal saddles. They are constructed differently and have very different physical properties.
They're normal saddles in the sense that they're mass manufactured saddles done from a single mould. I understand that they're not the same as normal saddles. But that's not revolutionary. It's revolutionary when you can walk into a Specialized shop, sit on a trainer that has a few sensors on the saddle for a while, pick one of their base designs that's then adapted to your ass. Noseless saddles are more revolutionary at the moment than 3D printed ones.
The entire point of them is the material itself moreso than the shape. I don't think there's much if anything to be gained by contouring a saddle like this to an individual ass because again the whole point is that it's compliant which makes it completely different than a saddle with a structure that would maybe benefit from being molded to an individual.
m3bas
by m3bas
I tried the Romin Mirro for a while but sold it and went back to the Pro Stealth, albeit the newer curved version. Couldn't get used to the squishiness.
Having said that I can see it being amazing on a gravel bike as its noticably smoother and more compliant.
robeambro
by robeambro
Thanks all for the good contributions.
Many have mentioned these saddles may be more comfortable - I wonder whether these would also be great for indoor training, where many of us - well, at least I do - struggle with comfort on anything longer than 40 minutes.
raggedtrousers
by raggedtrousers
robeambro wrote:
Thu Jun 09, 2022 10:15 am
I made this point earlier in the thread. The Power Mirror is the only saddle that lets me tolerate >90 min on the trainer.
I can do 4hrs outside on a range of saddles with no issue.
Usernamealex
by Usernamealex
The Chinese are making these saddles too which are plenty available on Ali.
Sent from my SM-G977N using Tapatalk
Eterna7m
by Eterna7m
Usernamealex wrote:The Chinese are making these saddles too which are plenty available on Ali.
Without knowing too much about the technique I’d be skeptical about these.
I’ve read plenty about there being a difference between fizik and specializeds padding… so I’d think these ones are definitely different.
Yoln
by Yoln
It's just one data point, but I haven't found any comfort improvement using an Antares Versus Evo.
For example a Berk Lupina, which is very close to the "perfect" fit for me with zero padding, is much more comfortable than the Antares that is close to perfect fit but not quite and with 3D printed padding...
#RETIRED# Lynskey “the Do-it-all Helix” 🧬:https://tinyurl.com/bdmb5y24
uppis
by uppis
raggedtrousers wrote:
Thu Jun 09, 2022 11:20 am
Same here, used to have trouble on trainer after 2-3 hours, with power mirror 5 hours goes pretty smoothly.
Aeo
by Aeo
Has someone tried the 3D printed saddles from Aliexpress?
https://www.aliexpress.com/item/1005004629571141.html
https://www.aliexpress.com/item/1005004347682124.html
The shape looks very much like the Bjorn Setka, the cover has a different pattern
Giant TCR Adv Pro Disc '17 · BH Lynx Race Evo '19 · Seraph GR029 '21 · Canyon Inflite AL '14
JeffK
by JeffK
I've tried my fair share of saddles, including the Specialized 3D printed saddles. Ive never really found a "perfect" saddle, but I think that might have changed. I recently got a Reform saddle which is heat moldable which helps it form fit exatly to your sit bones to eliminate pressure points. I tried the saddle on my gravel bike for a few longer rides initally and it was one of the best saddles I have tried without even doing the molding process. I still had one pressure point on my left sit bone, which is common for me, but it was very manageable. I did the heat molding process on the trainer and the last few rides on the saddle have been perfect! This might just be the perfect saddle finally! Check them out:
https://www.reformsaddle.com/product/se ... ke-saddle/
2021 Factor Ostro VAM
2021 Factor LS
2018 Trek Speed Concept
moock
by moock
Aeo wrote:
Wed Aug 24, 2022 4:57 pm
both links error 404.
Aeo
by Aeo
You will have to use an IP address from outside the EU to access. Currently many Aliexpress shops are not able to ship to the EU because of new laws.
Here is a snapshot of the first link: http://archive.today/zMiHL
mrlobber
by mrlobber
Aeo wrote:
Fri Aug 26, 2022 10:10 am
Both links work for me from inside the EU and all the buying buttons are available (I didn't complete the full buying process though).
Bikes I know something of:
Vial Evo Ultra | SS Evo 1 & 2 | R5D | S5 | S5D | P5 | O2 V.A.M D | AR FRD | Addict SL | Plasma 3 | SL6 | Orca | Orca OMX D | Boone D | 596
