I usually make my routes with garmin connect and I select the 'popularity trend' for mapping the route, maybe the 'follow routes' can solve the issue. Last month I did some routes from the strava map builder and so far no probs.ms6073 wrote: ↑Tue Jun 07, 2022 2:41 pmI think this typically occurs due to errors with the base map when a route is created. I have seen this on routes I mapped with RideWithGps in which I am clicking along the roads with the mouse and the segments appear to be a contininous line but actually includes a small jog or detour due to an erroneous road junction/intersection on the base map.BigBoyND wrote: ↑Sat Jun 04, 2022 11:04 amI've had this happen, rarely. I think it can happen where I drop points when building routes in Strava. Hasn't happened in a while so maybe it's been fixed with an update.Tonytony wrote: ↑Tue May 31, 2022 7:37 amWhen my navigation is on, I sometimes get a wrong pop-up when I need to make a turn. Most of the time it's a random turn somewhere else in the route. Someone has the same problem?
This is the only problem I've got with my edge 530, apart from that it's really good. Long battery life (20h with navigation), fast enough,...
New garmin product 1040edge, 840, 540
It's live on the Garmin site. Solar charging is the only difference between the 2 models correct?
Specialized Tarmac SL7
Specialized Crux
Velobuild 168
Trek Checkpoint ALR
Specialized Crux
Velobuild 168
Trek Checkpoint ALR
Frame color, and apparently the solar comes with a bundled silicone shell in case you don't like that frame color (but if you refuse the premium expense, your cheapness will be there for everybody to see, because neither the plain one nor the bundle list the shell)LanceLegstrong wrote: ↑Wed Jun 08, 2022 11:21 amIt's live on the Garmin site. Solar charging is the only difference between the 2 models correct?
Edit: no, apparently solar also gets more flash memory, up to 64g from 32. Might actually be a meaningful difference for those who purchase topo maps
Damnit Garmin, I know what you're doing.usr wrote: ↑Wed Jun 08, 2022 11:25 amyour cheapness will be there for everybody to seeLanceLegstrong wrote: ↑Wed Jun 08, 2022 11:21 amIt's live on the Garmin site. Solar charging is the only difference between the 2 models correct?
Specialized Crux
Velobuild 168
Trek Checkpoint ALR
Specialized Crux
Velobuild 168
Trek Checkpoint ALR
- eucalyptus
I’d definitely still be using a varia if they required a super exotic proprietary cable. I don’t ever ride without it.Treptay wrote:The 1040 looks nice, but too expensive. If the 540 and varia light get usb-c, I would be interested to buy them in the next year or two
I may understand not wanting to have twenty different cables lying the drawer but I do not think using a tiny miniusb to usb c adapter is a huge sacrifice for the varias benefit. .
Man, the 3 cycling computer makers now all have decerning features that I really like, but in the end, I kinda have to stick with the Bolt V2.
I really like the many little features like fueling reminders, pacing, altitude acclimatization etc. That Garmin has.
The climbing feature on both Garmin and Hammerhead is significantly superior to that thing on the Wahoo.
But I just can't justify putting 65g of extra weight on my bike for these gimmicks, when I otherwise spend top dollar to shed a few grams here and there.
A sub 85g 840, with all the same features, just smaller screen and less battery life would be perfect for me.
Cervelo P5 Disc (2021) 9.1kg
S-Works SL8 (2023) 6.3kg
My speculative prediction is that there won't be a 540 without a touchscreen, too much hassle (read: development cost) to make the otherwise identical software work with buttons alone. So in order to offer something in that price range that isn't artificially crippled, a 530 successor (540 or perhaps named different?) might just skip on screen and battery, so all the features of the 1040 in 130 size.FlatlandClimber wrote: ↑Thu Jun 09, 2022 7:59 amA sub 85g 840, with all the same features, just smaller screen and less battery life would be perfect for me.
As long as it has buttons additionally to control evrything during the ride, that would be fine. However, what would then be the difference between 540 and 840 ?usr wrote: ↑Thu Jun 09, 2022 8:51 amMy speculative prediction is that there won't be a 540 without a touchscreen, too much hassle (read: development cost) to make the otherwise identical software work with buttons alone. So in order to offer something in that price range that isn't artificially crippled, a 530 successor (540 or perhaps named different?) might just skip on screen and battery, so all the features of the 1040 in 130 size.FlatlandClimber wrote: ↑Thu Jun 09, 2022 7:59 amA sub 85g 840, with all the same features, just smaller screen and less battery life would be perfect for me.
Same as the difference between 1040 and 840 (and between 1030/830): size and battery runtime, obviously. (and a huge gap in price, but that has been true at least since the 530 and likely also long before)
They don't even combine buttons and touch for the top of the line 1040, which I was actually hoping for (5x: buttons, 8x: touch, 10x: both would kind of make sense I think), you certainly couldn't expect that for a device offered at half the price.
I thought the 530 and 830 had the same size and same battery life, only difference beeing the touchscreen? I don't see why they would change that with the 840 and 540.usr wrote: ↑Thu Jun 09, 2022 11:14 amSame as the difference between 1040 and 840 (and between 1030/830): size and battery runtime, obviously. (and a huge gap in price, but that has been true at least since the 530 and likely also long before)
The reason why I suspect a change is that their software development would me much easier if they could simply assume that every device the software runs on has a touch screen and not ask themselves, at every corner, "ok, now how do we get this to work on the 530?" That's a cost that would only make sense economically if they sold the one with the buttons at a premium. But the 530 was the lowest margin offering in that generation.
DCR mentions some hints given by Garmin employees that nothing of the new UI seen on the 1040 will appear on any x30ies, this would be consistent with "we removed the part that dealt with the button-only nature of the 530"
Yeah, they might repeat the "530 is the 830 just with buttons instead of a touchscreen and much cheaper because five is a lower number than eight", but I wouldn't be surprised at all if instead they returned to the size difference of the 800/500 and 810/510 era. Perhaps also some minor crippling software side, but that would seriously weaken its position against bolt2, I wouldn't expect that. A software-crippled 840 wouldn't be a 540, it would be an 840 explore.
