How long does disc brake pads last?
PoorCyclist
by PoorCyclist
On my gravel bike with OEM resin pads only last about 350 miles until less than 1mm pad left, but I change the out just in case (don't want to run out of pads suddenly)
I was wondering what kind of miles are we seeing for road use. I know after a major descent of 1000 meters vertical I can notice the pad thickness is decreased. Went from rubbing to no rubbing.
I would like to buy some spare pads but don't want to buy too many if they dont wear fast on the road.
Mocs123
by Mocs123
The real answer is it depends, but I tend to get about 2,500 miles (4,000km) out of my pads give or take - now do a fair bit of climbing and descending but no singular descent of more than about 1,000ft (333meters) at 9% so your mileage may vary.
2015 Wilier Zero.7 Rim - 6.37kg
2020 Trek Emonda SLR-7 Disc - 6.86kg
2023 Specialized SL7 - 7.18kg
bikeboy1tr
by bikeboy1tr
I have 3100km on my Campy Record pads and not alot of wear just yet but I am in a flatish area but the hills I do go to have only 100meters gain so nothing to crazy.
viewtopic.php?f=10&t=154188
2018 Colnago V2R Rim Brake
2019 Colnago V2R Disc Brake
TobinHatesYou
by TobinHatesYou
I think I have over 4000mi on my SwissStop Disc E pads, but I ride in groups with not a lot of braking...even when descending I'm only doing the bare minimum amount of braking. There is still tons of life left in the pads too, I might get ~7000mi out of them.
Cannoli
by Cannoli
4-5k miles on the road pads, 2-3k miles on gravel. Road pads are Swiss Stop EXO Therm2, gravel Shimano LO5A. The wife gets a bit more mileage out of hers, but she weighs as much as a hummingbird.
Canyon Aeroad CFR Di2 | Canyon Ultimate SLX 9.0 Di2 | Trek Domane SL5 Disc (Gravel Bike / Fly-Away Road Bike) | Orbea Tera H-30 Disc (Touring Bike)
TobinHatesYou
by TobinHatesYou
Cannoli wrote:
Wed May 11, 2022 11:48 pm
The E / ExoTherm semi-sintered compound is so good. It does get a bit squealy in the rain, but the quieter RS resin compound simply doesn't last long enough once the weather gets bad.
Cannoli
by Cannoli
TobinHatesYou wrote:
Thu May 12, 2022 12:01 am
Agreed. They are great pads but crazy loud in the rain. No worries though as I try to avoid the wet stuff if possible. I don't mind if it starts raining after starting in the dry, but I generally can't motivate myself enough to start off in the rain.
ms6073
by ms6073
PoorCyclist wrote:
Wed May 11, 2022 5:12 pm
Resin pads can see excessive wear in very dusty or wet conditions as the gritty sand acts as an abrasive in the dry and is super agressive when it is wet/muddy. I wore down a brand new set of resin pads in a 60-minute muddy CX race several years ago but this was exacerbated by the fact that I was using highly vented Ashima Ai2 Air Rotors which trapped the slurry in the vents while racing.
- Michael
Vespasianus
by Vespasianus
I get more than that on my MTB (Shimano). Something is not right.
I have over 5000+ miles on my current Campag road disc brakes with lots of life left.
Cinelli Superstar - Campagnolo H11
Tommasini Custom X-Fire gravel - EKAR
Cemicar
by Cemicar
Nobody yet mention the front and rear difference. Unless you use the rear brake 2 or 3 times more, the front pad has to wear out much earlier (2000km or such).
TobinHatesYou
by TobinHatesYou
Cemicar wrote:
Thu May 12, 2022 5:02 pm
It depends on how you ride. Even though I live on a big hill, most of my distance covered is fairly flat and in fast group rides or races. I try to ride as efficiently as possible and my brake pads wear at about the same rate.
Bfriesen
by Bfriesen
I just replaced my front brake pads for the the first time today. They were getting very thin and definitly needed to be replaced, but I bought the bike last year and have done 15000km so far. But same as others, mostly flat fast riding with very little decending in this area. Pads are Shimano K03s.
2020 Cannondale Supersix
2021 Argon 18 Gallium Disc
2018 Trek Crockett
Aeo
by Aeo
SwissStop Disc E pads on the rear: 13,900 km / 8600 mi - still going
On the heavy side and lots of elevation, no wet rides
Giant TCR Adv Pro Disc '17 · BH Lynx Race Evo '19 · Seraph GR029 '21 · Canyon Inflite AL '14
ABogle
by ABogle
I can normally get 4 thousand kms out of the front and a lot more from the rear. Note that I live in london and for my favourite and most frequent rides last around 6 hours of which about 2 hours is in quite built up areas with a lot of braking. But then again we don't have proper descents in southern england.
Ritsuke
by Ritsuke
My last set was around 6k km, the set before that - and during the harsh winter months - around 3k ...
Shimano resin
Road // 2023 S-Works Tarmac SL8 | Shimano Dura-Ace Di2 | Roval Rapide CLX
Gravel // 2023 Specialized Crux Pro | SRAM Force AXS | Roval Terra CL
Retired // 2022 S-Works Shiv TT // 2021 S-Works Tarmac SL7 // 2019 Specialized Allez Sprint Red Hook
