The Cyclingtips podcast also mentioned difficulties mounting GP5000s to the CLX2's if memory serves. Conti's generally appear to be more difficult on tighter rims than your average tyre.poppiholla wrote: ↑Thu Sep 29, 2022 7:01 amYesterday my new roval Rapide CLX 2 wheelset was deliverd. Super cool, but what a struggle to mount the tires to this rims. I am pretty good with mounting tyres and I had zero problems with wheels that I have. I also have zero problems with the Roval CL50 wheels. Mounting a set of Conti 5000s 28mm on the CLX 2 was a real struggle. I also tried the Specialized turbo coton's 26mm and that was a little bit easier but not much. Both I used Tubolito S inner tubes. I have blisters all over my hands. Do you have the same experience with the roval CLX or CLX 2 wheels?
New Roval Rapide CLX II
Forum rules
This board would be a nicer place if everyone would take themselves less seriously.
I almost miss Mr Search...
Thanks for the reply. I useally change tyres within minutes, but this Conti 500S with CLX 2 combo was a real struggle. That was really bad for my ego and myy hands.
Specialized Tarmac S-works SL7 (Satin carbon spectraflair tint)
Specialized Tarmac S-works SL6 (Green Cameleon)
Specialized Tarmac Pro SL6 Disc (Blue/Teal Sram Force AXS)
Specialized Epic Elite 29
Greetings from the Netherlands
I tried mounting a set of GP 5000S on my Rapide CL (which should be the same as CLX rim wise). It was a pain and I ended up mounting the original GP5000 instead as I need to be able to fix a flat. Seems like it's the same situation with these "new" wheels.
As we are talking Rovals... I was running Rapide CLX Gen 1 on a Tarmac SL7 build I purchased in 2022. The front wheel often made some clinging noise after breaking. Then I had a spoke failure on that front wheel when breaking before a very fast downhill corner. Not great but not the end of the world either.
Instead of fixing the spoke and trueing the wheel, my bike shop supplied me with a new front wheel on Roval Warranty. Fine by me. Problem solved I thought.
Now, one year later I experienced another spoke breaking on the front wheel, again gently breaking into a corner on a short downhill road. Do you guys also experience occasional spoke breaking on those stock Roval wheels?
Yesterday I removed the wheel, the tyre and TPU tube as I planned to ask lokal wheel builder to replace the spoke and check tensions all around.
-> I then noticed the rim tape being different, that front wheel it is tubeless reaedy version Rapide II which I wasnt aware of.
That Gen 2 front wheel might have nice ceramic bearing but comes in at 678 weighed grams (incl. tape) on my kitchen scale. How many grams heavier are the Gen 2 rims in front and back? Is the added 100g on the set mostly the rear rim or is it ca 50/50 grams added?
I am starting to get thoughts of selling the Rapides altogether and getting some individual build with Duke Rims instead - whats your thoughts on that swap? Riding lots of hills and long mountain climbs anyway.
