105 2x12 - R7170 (R7150) / R7120 (R7100) - di2 / mechanical (MY2024)
Karvalo
by Karvalo
ooo wrote:
Fri Jul 01, 2022 10:51 am
yes, I think combination of ultegra deraileurs + 105 cassette = my guess it is hg+ 2.0 capable
This is the exact opposite of correct.
1) cassette geometry of 105/ultegra looks the same, all ramps and holes are the same
You can't say this unless you've been looking at the back side of the sprockets, because that's where HG+ machining is.
2) IF this combo "ultegra deraileurs + 105 cassette" was not capable of hg+ 2.0, then CS-R7100 should not be listed as compatible with ultegra/dura-ace FD/RD, but it is listed as compatible
No. There is absolutely no reason why a given rear mech will not work just fine with either an HG or HG+ cassette, no matter which one it is 'supposed' to pair with.
ooo
by ooo
Karvalo,
Back of the cassette is the same, it is here 00:05 to 00:10:
https://dassets.shimano.com/content/dam/global/cg1SHICCycling/final/videos/cg2SHICComponent/360DegreeProductImage/CS-R7100-12-11-34T.mp4
d-a/ultegra derailleurs specced for fast hg+ 2.0 shifting, what you think will happend when you try to do shifting with max cage speed with 105 cassette?
105 cassette will allow max cage speed shifting settings or d-a/ultegra derailleur will fail?
if 105 cassette is listed as compatible with d-a/ultegra and it is not required to lower derailleur cage speed, cassette should be able to perform at hg+ 2.0 speed
Ritxis, last I heard it was not cancelled yet, planned for 2023, it will be announced closer to availability date
bobones
by bobones
Karvalo wrote:
Fri Jul 01, 2022 11:21 am
It isn't. HG+, either road or MTB is just a chain+cassette technology.
I don't think this is entirely accurate as the Shimano docs clearly mention improved chain retention and front shifting speed as a feature of HG+. At the back I'd agree, it's chain and cassette tech, but at the front, this road incarnation of HG+ seems to be a combination of chain, chainring shaping, and derailleur movement/speed.
Whatever the case, it's clear that the docs for the CS-R7100 cassette and FD-R7150 FD do not mention HG+ at all.
TerryDi2C
by TerryDi2C
The interesting bit (IMO) is that while the cassette is listed as "HG" vs "HG+" for R9200/R8100 (https://productinfo.shimano.com/#/spec/ ... 20Sprocket), the cassette sprockets are actually interchangeable between R7100 and R8100/R9200.... EXCEPT the 17T and 19T
https://si.shimano.com/#/en/EV/CS-R7100
ooo
by ooo
yes, this is one of the main arguments for hg+ 1.0 on 105 cassette. 17 and 19 have the same geometry too
17-19 is not listed, because Ultegra uses "Sprocket unit (17-19T)" - two sprockets on spider instead of individual sprockets
TerryDi2C
by TerryDi2C
Makes sense! I'll see if I can get some answers on this at Eurobike ;)
Karvalo
by Karvalo
ooo wrote:
Fri Jul 01, 2022 12:19 pm
Or it just means the mech doesn't care if it's shifting on HG+ sprockets it not, because why would it?
ooo
by ooo
"b" compatibility means, that you can mix and match sprockets of ultegra and 105 cassette
it would shifter well on monster cassettes that was created from combination of sprockets:
11T from ultegra
12T from 105
13T from dura-ace
14T from 105
15T from ultegra
17T-19T from 105
21-24-27-30-34T from dura-ace
bobones
by bobones
ooo wrote:
Fri Jul 01, 2022 11:58 am
Do you know if a rim-brake version is included in this potential mechanical release?
ooo
by ooo
no rim brake
satanas
by satanas
Boo, hiss!!!
cheapvega
by cheapvega
So disappointing. Just going to save up my pennies for R8050.
ultimobici
by ultimobici
cheapvega wrote:So disappointing. Just going to save up my pennies for R8050.
Why not mix Ultegra & 105? All you’d need from Ultegra would be the levers. Everything else from 7100 would be fine. Job done.
AW84
by AW84
Maybe this has already been discussed, but what is the typical entry to mid level bike (aluminum wheels, bars, etc.) this comes spec'ed on going to weigh now? I assume the typical 105 mechanical rim brake bike was 17-18 lbs?
rollinslow
by rollinslow
AW84 wrote:
Tue Jul 05, 2022 6:48 pm
Real weight with pedals you are definitely looking at 20lb plus range for a 105 di2 entry level disc bike.
Moots Vamoots RSL (2019)-Super Record 12
Cervelo S1 (2010)-Super Record 12
Kestrel RT700 (2008)-Dura Ace 9000
Mosaic GT-1 (2020)-SRAM Red viewtopic.php?f=10&t=174523
