cyclespeed
by cyclespeed on Thu May 26, 2022 1:23 pm
jlok wrote: ↑Thu May 26, 2022 12:33 pm
Woland wrote: ↑Thu May 26, 2022 11:55 am
A genuine question: why is the Protone considered aero? Is there any data to back it up or is it just based on Kask's marketing spiel? I've never seen any data presented anywhere, happy to be proven wrong.
Forget about proving it. You can't validate wind tunnel aero results in real world situations. Use common sense. Less vents means more aero.
Yep.
It is one of the smaller helmets out there, so presents less frontal area, and has less vents. A long tail is pointless unless you keep your head dead straight all the time.
kode54
by kode54 on Thu Jun 09, 2022 10:31 am
Good to know. Thx for pointing that out. Some shipments to the US have been delayed until The first week in July. It’s possible that this issue is being remedied?
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
kode54
by kode54 on Wed Jun 22, 2022 1:26 pm
My Protone Icon shipping has been pushed back to August 2022...so another month to sort out the niggles.
- Factor LS Disc
Robius
by Robius on Wed Jun 22, 2022 2:10 pm
Broady wrote: ↑Wed Jun 22, 2022 10:14 am
Ordered the medium and large, medium was too small and large was huge, it's a nightmare having a 59cm head.
Medium HJC helmets should work for you. They're also light and aero.
2016 Felt AR2 Di2
Retired:
2017 Giant TCR Pro 2
2015 Cannondale Synapse 6
ilovegadgets13
by ilovegadgets13 on Mon Aug 29, 2022 1:03 pm
Any more reflections on the new Icon vs. the old model? I've had 2 new ones now and although the dial has been fine, the ratchet strip at the back seems quite free-moving and therefore allows the cage to move around a bit when you move your head...the racthet strip in the old one had much more defined clicks between the ratchets if that makes sense?
poppiholla
by poppiholla on Thu Oct 13, 2022 3:45 pm
I bought the Kask Protone icon. I already have the old Protone. The new version has a more sturdy octofit retention system. Also the wheel is bigger and works fine now. I bought the updated version and problems are solved. There is one point that makes me wonder about the new version. The vertical stabilizer across the nape of the neck that provides ergonomic neck support is fine, but you can only move it up and down. You can't move it inside and out (horizontaly). This means that glasses with long arms still bumb againt the vertical stabilizer. Bummer. So I am wondering if other users come across this issue. Overall the new protone icon is better constructed then the old one and very comfy, but I wonder if I should upgrade for the amount of money Kask asks for it. The Protone icon in white looks amazing for sure.
Specialized Tarmac S-works SL7 (Satin carbon spectraflair tint)
Specialized Tarmac S-works SL6 (Green Cameleon)
Specialized Tarmac Pro SL6 Disc (Blue/Teal Sram Force AXS)
Specialized Epic Elite 29
Greetings from the Netherlands
crlincoln
by crlincoln on Sat Oct 15, 2022 8:27 am
poppiholla wrote:I bought the Kask Protone icon. I already have the old Protone. The new version has a more sturdy octofit retention system. Also the wheel is bigger and works fine now. I bought the updated version and problems are solved. There is one point that makes me wonder about the new version. The vertical stabilizer across the nape of the neck that provides ergonomic neck support is fine, but you can only move it up and down. You can't move it inside and out (horizontaly). This means that glasses with long arms still bumb againt the vertical stabilizer. Bummer. So I am wondering if other users come across this issue. Overall the new protone icon is better constructed then the old one and very comfy, but I wonder if I should upgrade for the amount of money Kask asks for it. The Protone icon in white looks amazing for sure.
I just got the new icon yesterday and have been comparing against my old one, it’s definitely better in quality and build, it looks slightly bigger overall, but not sure if it’s me comparing different colours. Old one black new one white..
yinya
by yinya on Tue Oct 18, 2022 6:38 pm
crlincoln wrote:poppiholla wrote:I bought the Kask Protone icon. I already have the old Protone. The new version has a more sturdy octofit retention system. Also the wheel is bigger and works fine now. I bought the updated version and problems are solved. There is one point that makes me wonder about the new version. The vertical stabilizer across the nape of the neck that provides ergonomic neck support is fine, but you can only move it up and down. You can't move it inside and out (horizontaly). This means that glasses with long arms still bumb againt the vertical stabilizer. Bummer. So I am wondering if other users come across this issue. Overall the new protone icon is better constructed then the old one and very comfy, but I wonder if I should upgrade for the amount of money Kask asks for it. The Protone icon in white looks amazing for sure.
It’s bigger, but for me back to “normal” Kask (medium) sizing. The previous Icon was smaller than expected.
