I tend to agree with that.TobinHatesYou wrote:The printed tape on my 202 NSWs never had any problems with Orange Seal. A sealant that has tape choice, tire choice limitations, an inability to be injected through the valve, that has balled up fibers, that is extremely sticky to the touch…
This is a failed product.
Silca Ultimate Tubeless Sealant
That’s a shame. I really hope they get these issues sorted out.
This forum has an extremely negative bias. Post anything positive and watch it be ignored.
So let me try a more negative tone!
Seriously... The printing coming off rim tape is not exactly world ending. The product being sticky on hands...? Yeah, you're touching it that much? Try gloves. Some of us never had any balled-up fibers and Silca have already acknowledged that and made changes to their process to avoid it. And it can be injected through the valve with the replenisher, just not on the initial setup.
Regular Stan's has failed to seal so many holes in the past for me. And strangely, that's what I want a sealant to do. Seal holes. But somehow that's not a failed product because I can insert more of something that doesn't work very well through the valve?
From Silca's update, it does sound like they're responding to some of these issues anyway, but regardless, some of us really are having the positive experiences Silca also describes in that same post.
At first it was just the text coming off, but by the time it was "ruined" it had somehow gotten "into" the tape and killed/ate away the adhesive. I wish I took a picture in hindsight. I thought maybe it was a chemical reaction caused by it being the same tape I'd used with my previous Bontrager sealant.manystyles wrote: ↑Wed Jul 20, 2022 9:25 pmWhat do exactly mean when you say ruin the tape?ghdana wrote:I am just seeing the update, but this stuff has been a mess for me, I do have a bottle with too much carbon fiber.
It ate away the text on my Roval tubeless tape and eventually ruined the tape after a month. Put some Stans tape in and it ruined that tape in like 2 weeks on one tire. Now using some other tape and going to add some of the replenisher, since it's very hot and dry in Arizona.
Probably going to try MucOff if this tape fails or just go back to the Bontrager I'd been using with 0 issues before.
With mega threads like this, I take all these comments with a grain of salt, cuz a lot of could just be perception.
Josh already addressed that bottling / amount of carbon in the latest batch of sealant.
“FFS use orange”. I might, but the promise of Silca’s stuff initially sounded great. I’m keeping at eye o this thread and any updates on their product page too.
I did take a picture of the "hole" that somehow appeared in my Stans tape. I've never had tape fail on me before so it's a bit perplexing. It looks like something "scratched" at it, despite the fact I never rode on it flat. The tear that goes down the tape is from when I removed it and it started to split.
https://i.imgur.com/6XDfmFO.jpg
7.7kg Allez Sprint
9kg Exploro Ultra
9kg Exploro Ultra
ghdana wrote: ↑Fri Jul 22, 2022 12:25 am
What's more is that Stan's/Tesa 4289 is a regular poly tape, which Silca claims should be unaffected. Looking at your photo, the edges of the tape look fine so my initial assumption stands that it's physical rather than chemical. The tape is likely getting damaged at the spoke holes because of repeated media/balled-carbon collisions with the tape at the sharp edges of the drillings.
[/quote]
So i had tape failure in my rear zipp, and tape damage in my front, as well as the carbon balls formed in a few days. The only problem with your theory is that the carbon balls all clumped together and stuck to my tire very quickly, they weren't freely floating around in the sealant.
[/quote]
Just had a similar failure like some people here. The sealant completely dried out just 1 month after replenisher top off. Fortunately, I was able to ride back home with 10 psi or less in my rear tire.
I'm switching to OS endurance.
Any idea how to remove this silca sealant layer on my tire? It completely covered my tire interior. It is hard to remove and break off easily.
I wet mine with warm water, then scrubbed - took me 30 minutes a tyre to get them new ish! I hate Silca still a month later!legstrong wrote: ↑Mon Aug 01, 2022 9:03 pmJust had a similar failure like some people here. The sealant completely dried out just 1 month after replenisher top off. Fortunately, I was able to ride back home with 10 psi or less in my rear tire.
Difficultly level "high" with the insert .
I have abandoned those with Silca, just too messy!
Cervelo P5 Disc (2021) 9.1kg
S-Works SL8 (2023) 6.3kg
Thanks will try this method.scottydonald wrote: ↑Tue Aug 02, 2022 8:24 amI wet mine with warm water, then scrubbed - took me 30 minutes a tyre to get them new ish! I hate Silca still a month later!legstrong wrote: ↑Mon Aug 01, 2022 9:03 pmJust had a similar failure like some people here. The sealant completely dried out just 1 month after replenisher top off. Fortunately, I was able to ride back home with 10 psi or less in my rear tire.
How is your rimtape looking? I am very reluctant to try the new batch silca sent me after looking at what it did to my rim tape.
No issues with the rim tape that I could detect. I have Peaties rim tape on this set, which should be a candidate for the graphics to come off based on what I have read in this thread.
https://www.bike24.com/p2314308.html
- wheelsONfire
Try TUFOs sealant as for now i will not swap it out!
Even tire pressure seems to remain very very stable.
I have one bottle per tire.
Bikes:
Open *UP* (2016.04.14)
