Ultralight bicycle parts by Lucendi
I managed to model the case for the Lupine Rotlicht Max. - The Lupine Rotlicht Max is a heavy rear bike light at 76,2 grams, but it shines bright and has great battery life, and is in my opinion well worth the weight.
The original case is made from aluminium and weighs a hefty 27,19 grams.
When printed in ABS, the case should weight a mere 10 grams. And bring the total weight down 23% to 59,0 grams.
The printed part;
After weight;
After weight;
That looks great!
If anyone else is interested in the bar end plugs, I have plenty of them already made and ready to be sent out;
Lucendi, love your work and the evolution of your designs! Have you thought about doing a Quarq battery cover (maybe even an aero one like the red cranks)
Cervelo S3 Disc - 6.78Kg/14.94Ib
Scott CR1 - 5.69Kg/12.54Ib
Scott Addict RC - 6.92Kg/15.25Ib
OnOne - Free Ranger - 8.68Kg/19.1Ib
Thank you kindly!stevec1975 wrote: ↑Tue Jun 28, 2022 8:44 pmLucendi, love your work and the evolution of your designs! Have you thought about doing a Quarq battery cover (maybe even an aero one like the red cranks)
I have not thought about Quarq covers, but judging by what pictures I can find of them it should be easy to do. I would need access to a Quarq crank and a cover though.
Thanks Lucendi - arrived already!
@ Beancouter
That was fast! Do you have a pic of them installed on the bike?
Frame they are going on is currently having the paint stripped off and then lacquered! All the bits are getting lined up for the build….
I managed to make som saddle rail clamps. Printed in the cf nylon and with M3 screws and nuts clamping them together.
Now I can figure out what attachements to make for them.
- MrCurrieinahurry
- Moderator
Very nice mate
Basso Diamante super record EPS 12
BMC slr01 ultegra Di2
Nice! I use this type of thing to mount my Varia light/radar. I have a few of them for different bikes, and they usually have a GoPro mount to which the Garmin quarter turn mount is screwed. Some track cyclists mount their computers under the saddle as they're not allowed to have a visible computer on their bars or stem. I suppose you could also mount some kind of holder or mini-bag for CO2 carts, a mini-pump, spare tube etc.
BTW, do your chain catchers work like the SRAM ones with a little screw that pushes against a tab to keep them from being rotated away by the chain? It's almost impossible to find the SRAM ones for sale now, and they're the only design I know that isn't susceptible to being pushed away by the chain.
The chain catcher has a manual setting for the angle. I have a sacrificial cylinder where the screw usually goes that you shave down to the desired length.bobones wrote: ↑Mon Jul 11, 2022 2:21 pmBTW, do your chain catchers work like the SRAM ones with a little screw that pushes against a tab to keep them from being rotated away by the chain? It's almost impossible to find the SRAM ones for sale now, and they're the only design I know that isn't susceptible to being pushed away by the chain.
Hi Lucendi,
Love your work! A while back you were looking into a more aero bottle cage [possibly with faring-type sides], which I was keenly keeping an eye on, but didn't have a need for it then.
But I decided to sell my TT bike and instead get an aero bike, settling on an Orca Aero. As you probably know though, the bottle solution is great for rides up to 60-90 minutes, but nothing more.
I would be hugely interested in whether you had any more thoughts on developing an aero cage for a normal 750ml bottle. I see the unreleased Giant Propel has quite an interesting solution, much like a mini-faring:
@ DaiD
Thanks for kind words!
I have had some help from another forum member to develop the aero bottle cage fairing design;
The fairing weighs more than the bottle cage, and they total about 20 grams together.
I can't 3D-print the entire bottle cage without it being massively heavy, but I could maybe combine a 3D-printed shell with some spring steel or carbon fiber to get the necessary clamping forces to hold the bottle secure.
