Im using it like 500km ago, no problems. Have to see that here i have not many hard braking points, but i think it wont be a problem. Ridenows are made compatible with rim brakes (like 32 grams, the light tubolito (20 grams) for example are not compatible with rim brakes).
33g Inner Tube - Ridenow TPU
Forum rules
A partial data point, until someone brings a better one, I have one on my REAR rim brake wheel and did around 900km going up and down the alps.kilo wrote:feedback of Ridenow tubes with carbon rims?
it seems that CYCLami tubes are more suitable for carbon rim brakes
So clearly not as stressfull than being on the front wheel but probably harder than people riding on flatter area.
Has anyone had good experiences with TPU tubes where the valve cores are removable?
Vittoria Ultra Lights are the only ones I’m aware of, but I haven’t used them. I’ve used Tubolito and Ridenow for about 2 years.
Reason I’m looking is bc of 80mm wheels that need valve extenders. Most TPU valve cores are glued in these days.
I was able to unthread the core of a Pirelli smart tube, but this required breaking the glue bond. Will try Teflon tape and re-gluing an extender.
If it’s too much trouble, I may just set up the 80mm wheels tubeless and see how that goes.
Use a mavic extension initially for non removable core-valves tubes. Your valve would be fully hidden.Turrifik wrote:Has anyone had good experiences with TPU tubes where the valve cores are removable?
Thanks. So it looks like Vittoria, Revoloop, and Aerothan have removable cores.
Is one more reliable than the others? I only ask because the early Tubolito days were a nuisance.
I can assure you guys that Schwalbe Aerothane definately has removalble core and I did put extender on those tubes for times. No issues.
Aerothan + Schwalbe extension (30mm and 60mm extensions possible).
Schwalbe are quite good. Low RR, high puncture resistance (see tests in German roadbike, BRR, Aerocoach).
Use Aerothan's for quite some time now.
I do (on a rear wheel, wanted to test prior trying on the front), I inspected the tube after around 1000km and there was no marks or signs of wear.orange77 wrote:Hello, anyone running the ridenow tpu in clinchers and veloplugs? Thanks
Enviado do meu SM-G973F através do Tapatalk
I ride on mountains (7-12km climbs, 15% max but I wouldn’t say they require high frequency of strong braking, so rim can cool down)
ThanksC36 wrote:I do (on a rear wheel, wanted to test prior trying on the front), I inspected the tube after around 1000km and there was no marks or signs of wear.orange77 wrote:Hello, anyone running the ridenow tpu in clinchers and veloplugs? Thanks
I will also try.
Thanks again and best regards
New experiment: valve stem leakage got clogged up by Vittoria pitstop.
My rear ridenow 29g road tube got a small leakage on the root of valve stem. I checked it by dipping it under water and seeing small bubbles coming up. I was wondering wether it is repairable with sealant.But as valve core is not separable, I decided to use an obsolete old sealant canister "Pitstop" which was designed to be used without vavle core removed. I used 1/3 of it and wait.
Now it holds air 90psi without any problem.
IMO, some tube sealants like Slime sealant or OKO automobile may work.
