New Cervelo Soloist Spotted...
skinnybex
by skinnybex
I've been told by 2 bike mechanics at both Excel and Competitive Cyclist that the Sram Dub T47 BB is correct to use. So $50 is starting point non ceremic. I know in the wording on the Cervelo website it says T47 BBright but it's a T-47 non wide which is needed. I believe you can configure that specific t-47 BB to be be assymetric.
23’ Cervelo Soloist / 6.88kg - 1x Crit Bike
22' Cervelo R5 / 6.35kg - Climbing Bike
22' Cervelo Caledonia 5 / 7.55kg - Travel Bike
21' Cervelo Aspero / 8.06kg - Gravel Travel Bike
23' Cervelo Aspero 5 / 8.25kg - Gravel Race Bike
jch3n
by jch3n
skinnybex wrote:
Fri Sep 30, 2022 8:44 pm
It looks like the Sram T47 BB is internal cup only. That will probably work but I think you would need some spacers on the DS. An actual T47 asymmetric BB has an internal cup on the NDS and an external cup on the DS.
dudemanppl
by dudemanppl
This will be the correct BB for T47a/Threaded BBRight DUB
https://www.performancebike.com/sram-du ... 3/p1308519
I generally would take any information gained from Competitive Cyclist with a large grain of salt.
OUGrad05
by OUGrad05
Anyone have any updates on the weight limitations? Is it really 194lbs on the size 61 frame?
bet609
by bet609
does any one know if there is aero test result from tour mag?
OUGrad05
by OUGrad05
bet609 wrote:
Mon Oct 03, 2022 1:20 pm
I haven't seen one yet. My local shop heard back from the rep on the weight issue. Looks like it will be addressed via updated docs for 2024 models.
kode54
by kode54
jch3n wrote:
Singular wrote:
Fri Sep 30, 2022 7:27 am
Campagnolo build issues (regarding the front derailleur) were mentioned recently - what about the BB, would one be able to fit Ultra-Torque cranksets on the special T47?
Ceramicspeed seem to have the most complete options for T47 asymmetric. They have one for Campagnolo UT. Otherwise you would probably have to buy 2 bottom brackets from somewhere else, one outboard T47 and one inboard T47, to piece together a single T47 asymmetric bottom bracket (which is outboard DS cup and inboard NDS cup)....might still be cheaper than a Ceramicspeed BB.
Hambini makes a T47a BB. I have one on my Factor Ostro (BBRight asymmetrical). One inboard bearing and one outboard. When I ordered my Ostro, I inquired Hambini and the BB came way before the frame arrived. So I think he has been making them all along.
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
skinnybex
by skinnybex
1st ride this morning on my Soloist and I must say the bike felt incredible. Although my ready to ride weight is 7.84kg it felt really lively and light underneath me on my punchy rolling hills and short power climbs. Also the 40mm Zipp SL70 aero bar with my shifters angled in felt amazing and effecient. I'll be triming the steerer shorter once I put the lower dust cover on since I wanted to ride it a few times first before making that decision.
inertianinja
by inertianinja
I'm strongly considering getting this bike.
I loved the old aluminum soloist, but ultimately had to abandon it due to the seat post slipping issue (by the end I had two brass shims epoxied to the seat post and it still slipped).
Right now my "second" bike is an open mold FM-066 which i love because unlike my Ostro, it's super agile, light, and snappy, just like my old soloist.
If the new soloist is like that, I'm sold.
skinnybex
by skinnybex
inertianinja wrote:
Sat Oct 29, 2022 9:26 pm
I had a 2022 R5 that was destroyed in May when I was hit by a truck that ran a stop sign. That bike handled so well with it's short wheelbase and chainstays and the Soloist has the same Geo with a bit lower stack so You'll likely love the handling and ride quality.
ddavis
by ddavis
skinnybex wrote:
Sat Oct 29, 2022 8:55 pm
looks incredible too!
MrCurrieinahurry
by MrCurrieinahurry
That does look very business like.,
Karvalo
by Karvalo
Very nice.
If companies are going to insist on routing cables through the headset that (on all but the most pure aero bikes) is how it should be done. Cables you can't see when you're riding but complete freedom to use whatever cockpit you want without even needing to worry about somehow matching it to proprietary shaped spacers. Trek already got that with the Emonda, and how much nicer do these look than the front of an otherwise lovely Supersix Evo because of it?
ome rodriguez
by ome rodriguez
Emonda and Supersix Evo cables doesn't pass through the headset. Soloist does right?
justkeepedaling
by justkeepedaling
Such a nice bike. Looks like the seat tube cutout isn't as close to tire as my old P2SL. I guess to allow for big tires.
Also, proof that you can use other stems than the Cervelo one. Good avenue for a little less weight.
I also turned my hoods in a similar amount recently and am really liking the change in wrist angle
