New Cervelo Soloist Spotted...
Just read the build manual and found this interesting note...
Seems quite unreasonable to me.
but jumbo visma is using the soloist with the fsa ACR systemTobinHatesYou wrote: ↑Tue Sep 13, 2022 5:43 pm
FSA ACR requires a larger diameter upper bearing than what's used on the Soloist.
The soloist routing is in front of headtube similar to cannondale supersix evo and aurum magma, doesn't pass through the headset bearingsmoock wrote: ↑Wed Sep 14, 2022 6:36 ambut jumbo visma is using the soloist with the fsa ACR systemTobinHatesYou wrote: ↑Tue Sep 13, 2022 5:43 pm
Incorrect, it does pass through the headset bearings and uses a D shaped steertube. Top bearing is 47mm OD, a regular size for a 1 1/4 lower headset.
False. It definitely goes through the upper bearing.ome rodriguez wrote: ↑Wed Sep 14, 2022 6:42 amThe soloist routing is in front of headtube similar to cannondale supersix evo and aurum magma, doesn't pass through the headset bearings
RTFM: https://cervelo.cdn.prismic.io/cervelo/ ... v2_web.pdf
So at least you can swap that lazy cockpit with something integrated? Should come with one TBH
His: Orbea Orca OMX
To be honest the stock cockpit with these slim spacers below the stem looks ugly. Doesn´t fit to the proportions of the bike frame.
May be the missing 7kg are the bike itself.dudemanppl wrote: ↑Wed Sep 14, 2022 3:46 amJust read the build manual and found this interesting note...
They're only using the bar/stem, which is compatible with any 1.125" steerer provided the right shaped spacers.
ACR utilizes a 1.5" upper so cables can squeeze around a 1.125" round steerer. The Cervelo steerer is a 1.125" D-shape and the upper bearing is 1.25"
The nice thing about this is it opens up a lot of options. You could fully integrate the cables with an UNO stem and a bar that has exit holes at the clamp (Vision Carbon Aero, 3T Aeroflux, etc.)dudemanppl wrote: ↑Wed Sep 14, 2022 6:47 amIncorrect, it does pass through the headset bearings and uses a D shaped steertube. Top bearing is 47mm OD, a regular size for a 1 1/4 lower headset.
