pmprego
by pmprego on Thu Jun 30, 2022 7:45 pm
yinzerniner wrote: ↑Thu Jun 30, 2022 7:32 pm
pmprego wrote: ↑Thu Jun 30, 2022 2:26 pm
It seems to be cable inside the stem... Why can't they follow a solution under the stem and not inside the stem. Specialized/trek solution is so simple, neat and easy to work with. They don't really have to reinvent the wheel...
CT has a full teaser article with lots of pics on the new Propel, and it looks incredible. And listed as 7KG race ready:
https://cyclingtips.com/2022/06/2023-gi ... ra-wheels/
Under the stem solution!! Yay!! Well done then giant!! Now we just need the official release info.
tmanley
by tmanley on Thu Jun 30, 2022 7:59 pm
I'm curious how high the seat post will eventually go. My legs are too long (ok, my height of 6'9" to be honest) for most of the mast-design frames - can't make the new Trek Madone work for me.
RDY
by RDY on Thu Jun 30, 2022 8:27 pm
pmprego wrote: ↑Thu Jun 30, 2022 7:45 pm
Think that might be the pro team rather than official solution. But if it works, who cares.
Also, still looks like it requires a hole in the back of the bar. No provision for semi-integrated per SMR etc.
RadB
by RadB on Thu Jun 30, 2022 9:14 pm
RDY wrote: ↑Thu Jun 30, 2022 8:27 pm
But allows for a range of bar stem combos, doesn't it? I'm happy -er, now let's see about delivery dates.
Hexsense
by Hexsense on Thu Jun 30, 2022 10:25 pm
After evaluating Trek and Scott new bikes geometry,
None of them are for me.
I have a preference for [slacker HTA+ longer fork offset] for longer front center (where front wheel locates vs bottom bracket) and BB drop between 70-75mm.
Trek: steep HTA and 45mm fork offset on my size (preferred 49-55mm like Specialized and Cannondale).
Scott: unknown fork offset but unlikely long when considering the wheelbase. A little tall bb.
I don't see full geometry of Giant yet. But I don't have a high hope. All prior Giants use the same fork offset for the entire size range. So I don't put my hope up for higher fork offset on small sizes this time.
Being picky about geometry makes my bike selection easy. I dissmiss 80% of the new bikes because the geometry aren't what I like.
Andrew69
by Andrew69 on Thu Jun 30, 2022 10:59 pm
FlatlandClimber wrote: ↑Thu Jun 30, 2022 10:13 am
Mega small bikes with 700c wheels looks ridiculous anyway. But I hardly ever see anyone riding 650 wheels on the road.
Can you even buy a top end extra small bike with 650 wheels?
Wife had a tri-bike many years ago with 650 wheels, but not a road bike
Pato
by Pato on Thu Jun 30, 2022 11:18 pm
Hexsense wrote: ↑Thu Jun 30, 2022 10:25 pm
I'm similar in your geometry criteria except that I'd preper a super short fork offset and that's the only reason I wouldn't buy the Madone with a 72 HTA...way too steep.
However my fear with the new propel is that the horizontal toptube in their smallest size might be around 48cm which looks really stupid if your seat height is around 65cm. I really hopes that's not the case.
Geometry asides, it ticks most of the boxes without a one-piece bar/stem, 0 offset seatpost, 2-bolt adjustable saddle, decent looking and usually Giant frames are not crazy priced.
cajer
by cajer on Thu Jun 30, 2022 11:25 pm
Andrew69 wrote: ↑Thu Jun 30, 2022 10:59 pm
No one makes decent tires/wheels in 650 so going down that route is pointless if you're racing
Hexsense
by Hexsense on Thu Jun 30, 2022 11:26 pm
Pato wrote: ↑Thu Jun 30, 2022 11:18 pm
huh?
So... you prefer short fork offset + slack HTA?
That means, you want high trail value?
Hmm. That's understandable but very rare for a road bike where we usually gravitate to 58-65mm trail since ~1970 to date.
Meanwhile, MTB's trail value creep up from 80mm-ish to over 110mm now.
Pato
by Pato on Thu Jun 30, 2022 11:49 pm
Hexsense wrote: ↑Thu Jun 30, 2022 11:26 pm
huh?
After doing a fork offset test (3 different lengths: 37/41/45) I was surprised how good the shortest offset felt combined with a 68 HTA. I was literaly riding without hands on gravel and cobbles with 28mm tires. When I tried it in the longest configuration there was no way I could even try removing both hands. Handling at speed felt really smooth so couldn't see any downsides to it, as a matter of fact in the descents it gave so much more confidence and when trying the long offset even though you'd gain some wheelbase it still felt twitchy in comparison.
renoracing
by renoracing on Thu Jun 30, 2022 11:54 pm
I really like a lot of things about this bike... I love my TCR, and specifically its downhill handling, which must be partially attributed to the 1 1/4 steerer and therefore stiffer front end. The idea of moving to this Propel is a definite possibility if they can manage to get the weight anywhere near the TCR(150g even).
The stem looks great, and allowing for aftermarket bars is a huge perk! Additionally, those bottle cages will work with a ton of other truncated down tube bikes I bet. I was recently looking to source a BMC cage to try on my 3T Strada, but these look like they'd offer an even better fit.
TobinHatesYou
by TobinHatesYou on Thu Jun 30, 2022 11:56 pm
cajer wrote: ↑Thu Jun 30, 2022 11:25 pm
Off the top of my head, Zipp and DT both make 650b wheels, and I know others do as well.
GP5K S TR and Schwalbe Pro One TLE come in 650b.
