I have just asked the same question to my friends...CustomMetal wrote: ↑Thu Jun 01, 2023 8:38 amIf we had a large image with all the current frames, but all black with no logos.. how many could you name at a glance without having to double take? The Trek Madone definitely... most others, even the S5 you might double take and question Bianchi?
new frame rumors for 2023?
Everything’s an SL7.
Though this kind of quiz would have been even harder in the days before carbon.
- Moderator
Oh the pinarello obviously
Allegra- Steel Lugs TBC
Aurelia- Stainless All Road 8.5kg
Bertha- TT 9.8kg
Perdita- Ti Turbo bike 8kg
Serenity- Ti Gravel 9.5kg/8.9kg
Verity- Ti Aero 8.2kg
Alya- Ti Climbing TBC
Bertha- TT 9.8kg
Scott Foil. Lapierre Xelius/Aircode. Cube Litening Aero with its weirdly skinny seatpost.
It has been done few years ago and it was way easier than expected. We focus on dropped seatstays but you have plenty of other details. You have all the unique designs (Dogma, S5, madone, aeroad, system6, the bizarre Bianchi) and then in the allrounders the they all have their unique features, trek as the external seatpost, last SSevo4 the deep section seattube, the Sl7 the rounder head tube, the BMC the special tube shapes…CustomMetal wrote:If we had a large image with all the current frames, but all black with no logos.. how many could you name at a glance without having to double take? The Trek Madone definitely... most others, even the S5 you might double take and question Bianchi?
I wonder what we would have said if forums were a thing in the 90s where bikes were made out of the same tubes!
C36 wrote: ↑Thu Jun 01, 2023 9:02 amIt has been done few years ago and it was way easier than expected. We focus on dropped seatstays but you have plenty of other details. You have all the unique designs (Dogma, S5, madone, aeroad, system6, the bizarre Bianchi) and then in the allrounders the they all have their unique features, trek as the external seatpost, last SSevo4 the deep section seattube, the Sl7 the rounder head tube, the BMC the special tube shapes…CustomMetal wrote:If we had a large image with all the current frames, but all black with no logos.. how many could you name at a glance without having to double take? The Trek Madone definitely... most others, even the S5 you might double take and question Bianchi?
Yep, even something like the silly wart for the seatpost binder bolt on the Wilier Zero SL.
Thing is, most brands keep design cues, little bits of brand identity and design language that make their bikes identifiable across generations, whether it be a more "square" design (BMC), sculpted head tubes (Trek), or whatever. Yes, you wouldn't distinguish them from a 2D blacked-out image, but you could still tell in real life. With this bike, the only "Ridley cue" that I can clearly see is the "kinked downtube" (don't know what to call it) around where the headtube touches the fork, which has been brought forward from the Kanzo. I am not a Ridley aficionado myself but had I seen that frame I could have probably guessed it was a Ridley without seeing any branding.CustomMetal wrote: ↑Thu Jun 01, 2023 8:38 amIf we had a large image with all the current frames, but all black with no logos.. how many could you name at a glance without having to double take? The Trek Madone definitely... most others, even the S5 you might double take and question Bianchi?
How many steel frames could you tell apart from eachother if the branding was removed? That's going to be a lot harder than trying to distinguish between these modern bikes. Most of these bikes actually have design cues that makes recognising them without the branding quite easily possible. Try doing the same with classic steel frames.CustomMetal wrote: ↑Thu Jun 01, 2023 8:38 amIf we had a large image with all the current frames, but all black with no logos.. how many could you name at a glance without having to double take? The Trek Madone definitely... most others, even the S5 you might double take and question Bianchi?
Well, the guy doing the photoshop on these renders did not deserve his paycheck that month. One, he photoshopped the old Force on the frame and second, I've never seen a bike in my life, who's chain would go around the sprockets in that waylazyriderzhao wrote: ↑Thu Jun 01, 2023 7:45 amFALCN RS
You could name more now than ever before. Anyone who would confuse the S5 and new Oltre wouldn't be able to pick any other frames out of a lineup anyway - the stems that point upwards are the only bits of the two bikes that look even remotely similar.CustomMetal wrote: ↑Thu Jun 01, 2023 8:38 amIf we had a large image with all the current frames, but all black with no logos.. how many could you name at a glance without having to double take? The Trek Madone definitely... most others, even the S5 you might double take and question Bianchi?
deadass, you'd think they're all using the same moldCustomMetal wrote: ↑Thu Jun 01, 2023 8:38 amIf we had a large image with all the current frames, but all black with no logos.. how many could you name at a glance without having to double take? The Trek Madone definitely... most others, even the S5 you might double take and question Bianchi?
I wonder which frame truly ushered in the modern design language we see nowadays. Of course the industry revolves around the SL7 right now but I think that the '18 Rose X-Lite minus the exposed cables wouldn't look so out of place todayCustomMetal wrote: ↑Thu Jun 01, 2023 8:38 amIf we had a large image with all the current frames, but all black with no logos.. how many could you name at a glance without having to double take? The Trek Madone definitely... most others, even the S5 you might double take and question Bianchi?
agreed - easy to miss as they aren't as distinctive as some other frames.TobinHatesYou wrote: ↑Wed May 31, 2023 8:46 pm
Horses for courses, I see fewer Aethos and more SL7s in crits and flat road races. I start to see some in hilly road races. I see a few on my large race pace group rides, and I see a ton on our hilly cul-de-sac sprint group rides in the hills.
One disadvantage of the Aethos is the S-Works is subtly branded and from afar it looks like any round tubed bike, so they are easy to miss.
StiffWeenies wrote: ↑Thu Jun 01, 2023 1:32 pmI wonder which frame truly ushered in the modern design language we see nowadays. Of course the industry revolves around the SL7 right now but I think that the '18 Rose X-Lite minus the exposed cables wouldn't look so out of place todayCustomMetal wrote: ↑Thu Jun 01, 2023 8:38 amIf we had a large image with all the current frames, but all black with no logos.. how many could you name at a glance without having to double take? The Trek Madone definitely... most others, even the S5 you might double take and question Bianchi?
2017 saw the SL6 and Teammachine. BMC already had dropped seatstays for a while.
IIRC, the BMC Team Machine from 2012 was the first frame with dropped seatstays. There was also a Racemachine in standard BMC white/black/red and a really fetching one in turquoise/orange/black. The colors matched my team colors at the time and I really wanted one!
