I find it a shame as well: Cannondale cranks are quite good, and very light as well. And if I understand correctly, the PF30/BB30 bearing size isn't particularly problematic (unlike trying to put 30mm axles on BB68 bottom brackets), the issues have more to do with Cannondale's tolerances being inconsistent.CampagYOLO wrote: ↑Fri Sep 16, 2022 11:47 amI've got 2 bikes running with BSA30 bottom brackets and there's no problems with either of them, BSA lets you run any crank you want as long as the spindle is long enough.KittenRidesBikes wrote: ↑Fri Sep 16, 2022 6:28 amYeah you're right the SSEvo didn't have Ai. The Carbon Topstone and the SSEvo CX did.TobinHatesYou wrote: ↑Fri Sep 16, 2022 6:16 amI don’t think the regular SSEvo ever had the Ai offset.KittenRidesBikes wrote: ↑Fri Sep 16, 2022 5:51 am
I've dealt with PF30 creak before. But yes. BSA is back. Ai is gone as well
I don’t understand the reluctance to go T47. If they’re sticking with 68mm wide BBs, they can just go T47e. No tool purchase issues that way. Seems like an accountant had their hand in that decision. BSA probably improves margins on complete bikes by a dollar or two.
As to why they did BSA and not T47, beats me. I have a t47 bike and its the shit.
The move from PF30 to BSA has probably killed off Cannondale's own cranksets for good and bikes will be specced with standard Shimano/Sram cranks which is a shame. I was always a fan of the look and the function of the high end Cannondale cranksets.
I suppose the move away from pressfit has a lot to do with many bike reviewers automatically considering it a negative and associating it with creaking, while generally looking positively at anything threaded. Meanwhile, almost every modern hub uses pressed in cartridge bearings and nobody cares. Actually the only time I experienced creaks due to poor bearing interfaces was in a hub with terrible tolerances, while all my pressfit BBs (including a BB30 Cannondale) have been fine.
