Quarq Dfour/Dub Chainline: Did it change from your 9100/8000/7000 arrangement?
JaeOne3345
by JaeOne3345
Wondering if any Dfour/Dub owners/users can chime in.
Did you have to adjust your hi and low adjustment much at all swapping from a normal 7000/8000/9100 chainset to the Dfour spider with 7000/8000/9100 rings? Is it a simple straight swap that maintains the same exact chainline?
Of course this is considering you have the proper bottom bracket/spacer configuration worked out.
