Washing AXS drivetrain
I have not found much discussion on this. I've seen some info on Srams site about not aiming water at where the battery connects or the derailleur pivots, or junction points between component sub-assemblies.
So do you not aim the hose towards the rear mech at all then? How else would you avoid everything they're saying. What if you have it on a gravel or mtb? That would be pretty difficult then. How about the shifters? They say you need some plug or something.
So how do you guys clean your Etap drivetrain?
Scott Addict RC 20 2021
Ridley Kanzo Adventure 2022
Same as every other bike I've had over the last 40 years. Hot water plus soap/shampoo, mild degreaser, then gently rinse with a hose.
(That includes many many km on etap and a fair few on AXS).
As long as you aren't a dick about it, a garden hose isn't going to do anything.
I've even seen SRAM tech cleaning bikes with a cordless pressure washer.
Bucket of hot soapy water, brush, sponge, rinse with low pressure hose or pump action garden sprayer and dry off excess water with a towel. Just don't use a pressure washer on it.
Keep batteries attached or use supplied blanks to cover terminals on derailleurs. Shifter blip ports should already by plugged with blanks or have blips attached.
No need to baby it.
No need to baby it.
I’d get a hose attachment that has several spray options. Try and find one with a “mist” setting. Supplies just enough want to wash away soap.
I’ll be washing my road bike with eTap for the first time this week.
Pressure washer on the lowest setting here. Obviously you don't want to aim focus the spray right on the battery, but I do get down in the pulley wheels and such. No issues.
Wilier Cento10AIR - SRAM Force AXS - Road/race
3T Exploro - SRAM Rival AXS XPLR - Gravel
Wilier Sestiere - Shimano Tiagra - Commuter
YouTube link: https://www.youtube.com/@JMCyclingVideos
Thanks. It doesn't seem that sensitive then. It sounded more complicated with Srams directions than it is. I didn't know you should remove the batteries though.
Likely not a bad ideal to wipe off the battery connections after washing or lubing as sometimes the battery will flash red if the contacts have crap between them even if the battery is not dead.
viewtopic.php?f=10&t=154188
2018 Colnago V2R Rim Brake
2019 Colnago V2R Disc Brake
I think SRAM are just covering themselves. Blasting a jet wash at any part of a bike isn't the best of ideas, and many customers don't seem to be able to tell the difference between a pressure washer at 100+ bar and a garden hose at 2.Roadbiker10 wrote: ↑Thu Jan 20, 2022 11:41 pmThanks. It doesn't seem that sensitive then. It sounded more complicated with Srams directions than it is. I didn't know you should remove the batteries though.
Taking the batteries off first is something I've only done when they need charging anyway or the bike is absolutely mindbendingly filthy (winter training rides, CX races) never bothered with any cover, just give the mechs a quick wipe down and a spritz with something to protect the terminals after i've finished.
Also have been known to use a compressor and a low pressure nozzle to blow all the water of the bike.
I don't bother taking the batteries off when washing either, but I have had 2 eTap RD failures that I put down to moisture ingress, so I am not going near them with a pressure washer at all.
First failure was with 11 speed RD which, after a couple of years, started discharging batteries within a week, then after around 3.5 years it started stalling on shifts. I ended up buying an A2 RD to replace this.
Second failure was Force AXS RD which after a couple of months started discharging batteries within a day. I got this replaced under warranty. Not really sure what happened here, but it was on my winter bike and I may have used a PW on it a couple of times. The replacement has seen a lot of wet rides but it remains fine.
Most of the stories of repaired RDs on here tell of dirty/muddy interiors pointing to water ingress as the culprit, and once they're cleaned up they work again. I am now a bit more careful about drying them off after wet rides and only using hose mist spray to rinse off soap.
Shouldn't.Roadbiker10 wrote: ↑Thu Jan 20, 2022 11:41 pmThanks. It doesn't seem that sensitive then. It sounded more complicated with Srams directions than it is. I didn't know you should remove the batteries though.
I've not found it matters much one way or the other.
Or at least, I've had no failures.
And the bike doesn't sit there wet for hours, and once the batteries are removed, the mech is electrically "dead".
Unless you acidentally ride down a mud filled trail and let it dry on your bike there is absolutleu no reason to get a hose near a road bike. You are not a pro mechanic in a horry to do 10 + bikes. You don't have unlimited access to bearings and parts, maybe you do, who knows, but there is simply no reason to wash a road bike like pro mechanics do. Use a sp[ray bottle with some soaby water and a rag or just use some bike polish.
LOL, there speaks someone whose never ridden anywhere with rain, snow, ice or dirt roads.
I am used to spraying pretty hard on the shower mode with the garden hose attachment piece. On the cassette especially and the pulley wheels. I don't aim it directly at the bearings though, but do it from a different angle. But you're right, road bikes don't require that kind of water pressure.OnTheRivet wrote: ↑Fri Jan 21, 2022 7:46 pmUnless you acidentally ride down a mud filled trail and let it dry on your bike there is absolutleu no reason to get a hose near a road bike. You are not a pro mechanic in a horry to do 10 + bikes. You don't have unlimited access to bearings and parts, maybe you do, who knows, but there is simply no reason to wash a road bike like pro mechanics do. Use a sp[ray bottle with some soaby water and a rag or just use some bike polish.
