Lightest Road Helemet
I remembered reading somewhere that CPSC can make helmet worse than CEN.
CPSC make sure the helmet is effective at preventing skull crack. But to do so, usually helmet have to be stiffer for harder impact that it is worse at preventing concussion at a lower impact force.
So, argument say, if the impact is so hard that you risk skull crack you'd have concussion already. You have lower chance of dying but still have brain damage. But making helmet foam softer, it's better at reducing concussion for all lighter impact.
Is the CCT the knock off version of the CTT?
Sent from my COL-L29 using Tapatalk
Cut your hair in a helmet kind of fashion, no one will be able to tell
Eating trash'n riding fast
- Moderator
Best answer yetjohanalexander wrote: ↑Tue Dec 07, 2021 10:17 pmCut your hair in a helmet kind of fashion, no one will be able to tell
Allegra- Steel Lugs TBC
Aurelia- Stainless All Road 8.5kg
Bertha- TT 9.8kg
Perdita- Ti Turbo bike 8kg
Serenity- Ti Gravel 9.5kg/8.9kg
Verity- Ti Aero 8.2kg
Alya- Ti Climbing TBC
Bertha- TT 9.8kg
My Kask Valegro (non-WG11) and Abus Airbreaker both in size medium are 210g.
The European Kask Protone is only 15g more than the Valegro (I have both and they are 225g and 210g respectively in M with the straps trimmed to size). I understand that there's a much bigger weight difference between the two in other markets. Protone also probably moderately aero?
No, just different. National standards all use different testing techniques whose effectiveness vary massively depending on the kind of crash you may have. Fundamentally the benefits of cycling helmets are still debateable. Picking a National standard isn't a reason to choose.
They are an established motorcycle brand. I have three of their helmets and the Furion is very good and light
I doubt most courses are long enough, or the riders sat down long enough to even generate a stable flow. It's the one road cycling discipline where light weight over aero actually makes sense most of the time.TobinHatesYou wrote: ↑Mon Dec 06, 2021 9:11 pmThe Limar Ultralight Evo is pretty light, but I would guess an aero road helmet would actually be faster for most hill climb courses.
Longer, flatter courses do exist, but they are not normal. The aim is generally short, sharp, steep and vomit at the top.
I've done a few (25+ years ago!) and very very few of them required you to be seated for more than a few seconds at a time, most wouldn't even have required a saddle!
- Moderator
Yeap aero is pointless as I am out of the saddle from the gun! Hence why I have focused on on weight and stiffness for my build and what I wear..ghostinthemachine wrote: ↑Thu Dec 09, 2021 10:15 amI doubt most courses are long enough, or the riders sat down long enough to even generate a stable flow. It's the one road cycling discipline where light weight over aero actually makes sense most of the time.TobinHatesYou wrote: ↑Mon Dec 06, 2021 9:11 pmThe Limar Ultralight Evo is pretty light, but I would guess an aero road helmet would actually be faster for most hill climb courses.
Which is why I would always just wear a cap before...
Bertha- TT 9.8kg
Bertha- TT 9.8kg
