Clavicula 12sp chainings?
Really want to continue using my THM Clavicula with 9200, what's the options for chainrings - TA are my usual go-to rings but they've nothing listed on their site.
I'm using Extralight rings with my 12sp chain right now.. everything else is 11.. but I dont see why whatever you are using now would not work.
2024 BMC TeamMachine R
2018 BMC TImeMachine Road
2002 Moots Compact-SL
2023 Pivot E-Vault
2023 Pivot E-Vault
- Moderator
Carbon Ti?
Allegra- Steel Lugs TBC
Aurelia- Stainless All Road 8.5kg
Bertha- TT 9.8kg
Perdita- Ti Turbo bike 8kg
Serenity- Ti Gravel 9.5kg/8.9kg
Verity- Ti Aero 8.2kg
Alya- Ti Climbing TBC
Bertha- TT 9.8kg
- robbosmans
- Moderator
- Contact:
Shimano 12s is compatible with all 11s chainrings
Yes. My current Carbon-Ti chainrings are marked 11/12 sp.
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
- Factor LS Disc
Extralite would be great but they only make 110BCD rings, I need 130BCD
- robbosmans
- Moderator
- Contact:
You don’t need 12s specific chainrings, just use what you where using before
Has anyone tried to mount the DA 12s chainrings to the THM crankset? I have not found consistent positive feedback on any non-Shimano chainring with the new 12s groupset. I would rather use the DA chainrings to get the best performance, if they fit. Does anyone know if they fit?
Clavicula has 5x110 and DA Chainrings have 4x110.JOliver wrote: ↑Fri May 27, 2022 9:04 pmHas anyone tried to mount the DA 12s chainrings to the THM crankset? I have not found consistent positive feedback on any non-Shimano chainring with the new 12s groupset. I would rather use the DA chainrings to get the best performance, if they fit. Does anyone know if they fit?
