Caad 13 owners
If it's the rim brake model that I have then you'll eventually discover that the bridge doesn't actually fit the the rim brake frame and eventually Cannondale discovered you can't fit it either ie you can't use it. That was the eventual feedback I had after much emailing backwards and forwards. It does cause the mudguard to rattle slightly so I made my own modified brake bridge support (instead of the supplied one you need for the dual mount brakes) to give more clearance and also to fix the mudguard to it. My build write up including the mudguard attachment is here... viewtopic.php?f=3&t=159994 specifics about mudguards start on page 3. If you have a disc model then you shouldn't have any problem attaching the mudguard bridge.
Hi, thanks for your help.c60rider wrote: ↑Tue Nov 30, 2021 12:15 amIf it's the rim brake model that I have then you'll eventually discover that the bridge doesn't actually fit the the rim brake frame and eventually Cannondale discovered you can't fit it either ie you can't use it. That was the eventual feedback I had after much emailing backwards and forwards. It does cause the mudguard to rattle slightly so I made my own modified brake bridge support (instead of the supplied one you need for the dual mount brakes) to give more clearance and also to fix the mudguard to it. My build write up including the mudguard attachment is here... viewtopic.php?f=3&t=159994 specifics about mudguards start on page 3. If you have a disc model then you shouldn't have any problem attaching the mudguard bridge.
I have the disc model. The screws that are in the frame are too short, they only have a couple of mm showing once fed through the mount so they won't attach into the frame.
Seems really strange...?
This is what the mount and supplied screws should look like so it sounds like they've sent you the wrong screws.Gaz9 wrote: ↑Tue Nov 30, 2021 6:50 pmHi, thanks for your help.c60rider wrote: ↑Tue Nov 30, 2021 12:15 amIf it's the rim brake model that I have then you'll eventually discover that the bridge doesn't actually fit the the rim brake frame and eventually Cannondale discovered you can't fit it either ie you can't use it. That was the eventual feedback I had after much emailing backwards and forwards. It does cause the mudguard to rattle slightly so I made my own modified brake bridge support (instead of the supplied one you need for the dual mount brakes) to give more clearance and also to fix the mudguard to it. My build write up including the mudguard attachment is here... viewtopic.php?f=3&t=159994 specifics about mudguards start on page 3. If you have a disc model then you shouldn't have any problem attaching the mudguard bridge.
