Short Non-removable Core Presta Valve Tube
Lelandjt
by Lelandjt
Who makes tubes with sub-40mm valves that don't have a removable core. My stash of Kenda Superlite 18-23 tubes with 25mm valves is getting low. I'd like more of the same but can't find them.
ooo
by ooo
700 x 18-20c presta 36mm non-removable 75g
Michelin Air Comp Latex Road Inner Tube
https://www.wiggle.co.uk/michelin-air-comp-latex-road-inner-tube
Lelandjt
by Lelandjt
ooo wrote:
Fri Nov 26, 2021 8:01 pm
Thank you. What's the consensus on latex tubes with carbon and rim brakes? It says 18-20mm and I use 23mm tires, no problem?
Anyone know of anything shorter and not latex?
MikeD
by MikeD
I would get the proper size and not if you do mountain descending.
Lelandjt
by Lelandjt
MikeD wrote:
Sat Nov 27, 2021 4:21 am
I agree on both counts. The search continues.
Nickldn
by Nickldn
Giant sell inner tubes in sensible sizes and with non removable cores.
https://www.giantbikespares.com/Giant-I ... il/3-43702
Giant Propel Advanced SL Red Etap 11s Easton EC90 wheels CeramicSpeed BB Zipp SL70 bars 6.5kg
Vitus ZX1 CRS Campy Chorus 12s Bora WTO 45 disk brake wheels Zipp SL70 bars 7.5kg
SL8 build with Craft CS5060 Wheels in progress
Lelandjt
by Lelandjt
Nickldn wrote:
Sat Nov 27, 2021 9:46 am
That'll work. A thinner, "lightweight" tube would be nice and an even shorter valve would be too.
Nickldn
by Nickldn
Lelandjt wrote:
Sat Nov 27, 2021 6:18 pm
As you probably know Conti do Supersonic tubes, which are very lightweight butyl. Shortest valve length is 42mm and the cores are removable though.
