You can disagree, but you'd be wrong. Yeah, the "horn" is obviously different, but if you're holding the shifters like normal, the ergonomics are the same. I can say that because I literally just went to my garage and fondled both hydro and mechanical shifters thoroughly.RobJ wrote: ↑Fri Nov 26, 2021 12:03 amI would disagree fully. This isn’t the best picture but shows the much larger “horn” on the hydro. Plus the steep angle of incline on the horn. Some difference in the body too. The body is wider too. I personally rode on the horns a fair amount, sometimes when climbing or a hard flat TT type effort.goatalope wrote:I don't know what these people are talking about. Ergonomics of Sram mechanical cable brakes and sram mechanical hydro brakes is nearly identical (if not totally identical). Hydro has a big nub, but not like people typically hold that part of the lever. Aesthetics might looks off, but ergonomics would not be a problem.
SRAM hydraulic vs mech hood shape
