Hello, I am hoping someone can assist in recommending the proper end caps to use when converting from Novatec Shimano 11 speed to Novatec B2 XDR driver? I have 130mm QR and as far as everything I have read my setup should work, I think I am just hung up on end caps at the moment.
I am curious if I just need the drive side XD end cap, or something different.
Thank you for your help!
Update: My oil seal on the outside (end cap side) of XDR driver needed replaced, and spacer used to avoid cassette rubbing on my wheel spokes. The Jeckyl's post on here was 100% helpful in detailing everything the PowerTap G3 requires for AXS conversion.
If the moderator chooses to delete this post that is fine with me. I'm sorry I'm new here and trying to avoid multiple posts on same topic.
PowerTap G3 SRAM AXS Conversion
