No one claimed 100% rim bike demand.
Already answered your question in previous post.
The final answer is $. Higher revenue.
Actually, brake track longevity is significantly longer on carbon tracks. Lightweights excluded since they only use like 2 plies on their track but I can't recall the last time I've seen someone post a photo of a fully worn brake track. I put 20k miles on my first set of Reynolds DV46 and the brake track was still fine, no visible grooving. I think I have about 10k on my Bontrager XXX and they still have all the texture.StiffWeenies wrote:Rim brakes would mean that my very expensive carbon wheelsets are essentially consumables, no? I get that squeezing the brakes on a set of Meilenstein Obermayers won't cause them to spontaneously decompose, but it's still something that I don't like stomaching.
That's why I run HED's Jet RC6 Black on my Oltre XR4 with eeBrakes. I have way less qualms about braking on an alloy brake track.
Yes, can we please have some proof to substantiate this assertion that carbon rims 'melt', or 'spontaneously decompose' from rim braking.RyanH wrote: ↑Tue Oct 26, 2021 7:48 pmActually, brake track longevity is significantly longer on carbon tracks. Lightweights excluded since they only use like 2 plies on their track but I can't recall the last time I've seen someone post a photo of a fully worn brake track. I put 20k miles on my first set of Reynolds DV46 and the brake track was still fine, no visible grooving. I think I have about 10k on my Bontrager XXX and they still have all the texture.StiffWeenies wrote:Rim brakes would mean that my very expensive carbon wheelsets are essentially consumables, no? I get that squeezing the brakes on a set of Meilenstein Obermayers won't cause them to spontaneously decompose, but it's still something that I don't like stomaching.
If you search, there's several threads on this topic. Carbon rims last a very very long time.
No, no, no. You stated:openwheelracing wrote: ↑Tue Oct 26, 2021 7:44 pmNo one claimed 100% rim bike demand.
You're arguing that the demand for rim brake bikes is higher than what is being produced. That means the demand for rim brake bikes is not being met. So, if the demand is not being met, why doesn't some company fill that demand by manufacturing lots of rim brake bikes? It's a pretty sound business model -- produce something where demand exceeds the supply.When they make 10 disc and 1 rim, of course the ratio is 10:1. These numbers are manufactured, not indicative of actual demand.
Thank you. I learned something new today, now time to add new wheelsets to my shopping cart...RyanH wrote: ↑Tue Oct 26, 2021 7:48 pmActually, brake track longevity is significantly longer on carbon tracks. Lightweights excluded since they only use like 2 plies on their track but I can't recall the last time I've seen someone post a photo of a fully worn brake track. I put 20k miles on my first set of Reynolds DV46 and the brake track was still fine, no visible grooving. I think I have about 10k on my Bontrager XXX and they still have all the texture.StiffWeenies wrote:Rim brakes would mean that my very expensive carbon wheelsets are essentially consumables, no? I get that squeezing the brakes on a set of Meilenstein Obermayers won't cause them to spontaneously decompose, but it's still something that I don't like stomaching.
No need to repeat your question baiting me to repeat my answer. See posts above.tomato wrote: ↑Tue Oct 26, 2021 7:57 pmNo, no, no. You stated:openwheelracing wrote: ↑Tue Oct 26, 2021 7:44 pmNo one claimed 100% rim bike demand.
The final answer is $. Higher revenue.You're arguing that the demand for rim brake bikes is higher than what is being produced. That means the demand for rim brake bikes is not being met. So, if the demand is not being met, why doesn't some company fill that demand by manufacturing lots of rim brake bikes? It's a pretty sound business model -- produce something where demand exceeds the supply.When they make 10 disc and 1 rim, of course the ratio is 10:1. These numbers are manufactured, not indicative of actual demand.
You haven't answered it at all. If this unmet demand for rim brake bikes exists, why are there no companies jumping in to take advantage of it?openwheelracing wrote: ↑Tue Oct 26, 2021 8:04 pmNo need to repeat your question baiting me to repeat my answer. See posts above.tomato wrote: ↑Tue Oct 26, 2021 7:57 pmNo, no, no. You stated:openwheelracing wrote: ↑Tue Oct 26, 2021 7:44 pmNo one claimed 100% rim bike demand.
That's exactly how manufacturers want it. Pure marketing genius. Learn from the best: Rolex.
But Aethos is not rim brake, it is still a disc brake bike which is contradictory to lightweight.openwheelracing wrote: ↑Tue Oct 26, 2021 8:38 pmThat's exactly how manufacturers want it. Pure marketing genius. Learn from the best: Rolex.
Push disc now, raise prices as high as possible, increase weight as much as possible. Drop the Aethos. Rinse and repeat.
New to the sport folks want disc because they all have ridden rim brakes at some earlier point in their lives and those usually happened to be terrible examples of rim brakes.TobinHatesYou wrote: ↑Tue Oct 26, 2021 7:02 pmNew to the sport folks generally don’t want anything in particular.
Off topic here, but the Beta vs VHS/HD DVD vs Blu-ray was settled way before the masses had a say.maxim809 wrote: ↑Tue Oct 26, 2021 8:19 pmHate to use this analogy because at its core these are very different comparisons, but it's like the videotape format wars between Betamax vs VHS. Or HD DVD vs Blu-ray.
At some point, it's very unlikely to tip the scales back once one of the formats has reached mass adoption.
