The Great Braking Debate Thread (Disc/Rim/Cantilever/Fixie/InsertNewTechHere)
RyanH
by RyanH
We mods will probably instantly regret this but this will be the designated area to discuss anything braking related like rim vs disc.
A few ground rules:
  • This isn't a safe space, if you attack other members you will be put on holiday
  • If you are easily triggered, it's probably best to avoid this thread
  • This thread doesn't represent the views of the mods and those that run the forum, we are just tired of dealing with the same pop up thread multiple times a week to rehash this topic from scratch as if it never existed. Collectively, our opinion is to ride what you like but that isn't good enough for some of the members, particularly the new ones that don't want to use the search button.
  • Again, you will be banned if you step out of line. There is less tolerance here than other threads. Be forewarned. Zero tolerance for ad hominem attacks. Best advice is that if you don't want it to be read out loud in a deposition, don't post it here...
Strava
Not for the sensitive types. My Instagram reviews
The Ex's: I've lost track...
maxim809
by maxim809
I’d like to thank Ryan for doing god’s work.
After having developed a nervous tick and an ulcer from reading over 9000 braking debate threads, I am excited to announce that I am ready for more!
mrlobber
by mrlobber
:thumbup: about time
Bikes I know something of:
Vial Evo Ultra | SS Evo 1 & 2 | R5D | S5 | S5D | P5 | O2 V.A.M D | AR FRD | Addict SL | Plasma 3 | SL6 | Orca | Orca OMX D | Boone D | 596
Singular
by Singular
I will be racing on cantis tonight. Welcome to the dark ages!
BdaGhisallo
by BdaGhisallo
Coaster brakes too?
basilic
by basilic
since I asked for the thread, my summary of the arguments, framed positively ;-)
Advantages of disk
- better braking in the wet
- no limit on tire size
- possible to swap 700 for 650B
- no abrasion of rims
- manufacturer buy-in (availability and continued development)
- evolving tech on the road, may get better over time
Advantages of rim
- lighter (3-400g)
- cheaper
- easier maintenance (at least for those who have ridden rim brakes for a while)
- mature technology
- allows flexier/more comfortable frame/fork/wheel
corky
by corky
basilic wrote:
Tue Oct 26, 2021 11:14 am
Advantages of disk
Advantages of rim
- lighter (3-400g)
- cheaper
- mature technology
For me, who runs both systems, the advantages of disks are only apparent when the roads are wet and then they are offset by the squeal. Sometimes I can deal with it but mostly not.
I am hopeful they(mfgrs) can solve this soon.
With respect to maintenance, rim is easier but is required more. To me though, this is isn't a huge issue....(so far)
tjvirden
by tjvirden
This is a great idea; thanks for the suggestion and thanks to the mods for organising it (and for putting up with our endless discussion [arguing] in countless previous threads).
I'll add an advantage for each:
Disc advantage: Better aero in some circumstances
Rim advantage: Better aero in some circumstances
I use both rim and disc, on road bikes, and plan on doing so indefinitely. I'll quibble over the weight difference - it's a difficult comparison to make, but I think can now be as low as a 150g advantage for rim brakes, trying to use approximately equivalent parts. Though sometimes disc is much heavier.
naylor343
by naylor343
corky wrote:
Tue Oct 26, 2021 11:33 am
This is also my main dislike with disk brakes, the dreaded squeal.
I rode a mountain sportive in Catalunya 3 weeks ago, plenty of wet descending. After being surrounded by a peleton of riders on disk brakes I can still hear the horrendous cacophony of sound ranging from a strangled cat to a ocean liners fog horn.
In addition, on a purely financial front, is the necessity to buy a complete new bike, frame + groupset + wheels.
Other than this, I am resigned to eventually converting to discs and don't really care who rides what. I must add though, that I do not see why cycling needed road discs. As someone who first raced in 1980 and is still riding daily in the high mountains, I have never felt in need of more than the rim brakes I have always used.
But to the industry, before trying to solve any other issues, please, please address the pad/disk wet weather squeal and make everyone's day out more pleasurable.
mgrl
by mgrl
Cheap disc is much much heavier than cheap rim, the gap decreases the more money you put in.
An additional advantage of disc brakes is that you won't get high spec bikes with horrorshow integrated brakes with very little stopping power, as was the fashion with some rim aero/tt bikes.
robbosmans
by robbosmans
This time of year the shop gets filled with clogged rim brakes and squealing disc brakes, both a result of bad maintenance.
However a squealing disc brake is a lot easier and faster to fix than a clogged rim brake (talking about full caliper disassembly and housing replacement).
rudye9mr
by rudye9mr
Monoblock forged calipers with proper pad set back mechanism, pad compound and rotor tech pls...would love to see disc brakes a few generations from now
ooo
by ooo
Current disc tech soon to be obsolet, wait for Road Boost (aka InsertNewTechHere) to be safe with even left/right spoke tension front disc brake wheels
Butcher
by Butcher
So its not going to be like Thunder Dome? Two man enter, one man leave.
Cemicar
by Cemicar
The war is always between disc and rim, but I think it also should be hydronic vs mechanical. I feel like mechanical discs have been overlooked by the industry and customers. Hydronic is definitely better but has several big cons and it's essentially "too much" for a 105-level bike, or any bike that doesn't care about aero (e.g. Aethos). I love discs but my next bike is supposed to avoid those horribly big hydronic hoods by moving to the mechanical disc calipers.
