Rotor Aldhu Spacing
lord_brush
by lord_brush
Quick question, just got an Aldhu 24mm ctankset, and bit confused with the spacer/ O ring fitment.
By O ring, I mean the small gaskets they spec for fitment with the thin spacers for the 24mm axle.
Do the o rings go outboard of the spacers, or inboard? I'm probably missing something, as the Rotor documentation seems very good, but can't quite figure this one out...
The right to bear arms is slightly less ludicrous than the right to arm bears. (Chris Addison)
jfranci3
by jfranci3
lord_brush wrote:
Tue Oct 19, 2021 7:05 pm
Outboard the spacers
Tip:
tighten the arm bolt most of the way, then (while pushing against the drive side firmly) hit the arm inward with a plastic/rubber hammer to make sure the arm is fully seated on the spines. A little Loctite green (same stuff you might use on BB bearings) is a good idea on the splines.
If you've got a Trek BB90, don't add the spacers, you'll just destroy the BB bearings in short order. If you follow Rotors instructions you'll ruin the NDS arm / spindle because the splines won't fully seat. They won't warranty it.
klozzle
by klozzle
Isn't it dependent on the BB you have. Not an expert, but I think I used the chart at: https://rotoramerica.com/pages/crankset-support
Sent from my SM-G996B using Tapatalk
klozzle
by klozzle
Wait, I think I just installed my crank arm wrong. You can ignore that comment.
lord_brush
by lord_brush
Cheers. I think it's gone ok 😬
It's regular BB86 and it's seems it's gone on ok initially with the preload ring backed right off. I guess if it beds-in and loosens a bit, then I can dial some preload on before re-torquing.
It's going to be on the turbo for the foreseeable anyway, so I guess if it falls off, I'm only zero meters from home!
jfranci3
by jfranci3
Bearing -> external seal -> oring-> spacer -> arm
lord_brush
by lord_brush
would that not be 'inboard', of the spacers then?
