Best "no proprietary parts" bike ?
Nodejs53
by Nodejs53
Hi
I was wondering what's is the best "no proprietary parts" bike at the moment ?
Looking for a bike easy to service, easy to adjust and can be upgraded / maintained easily.
Thanks for sharing
Mocs123
by Mocs123
Specialized Aethos S-Works?
2015 Wilier Zero.7
2017 Trek Domane SLR-7 Disk
MikeD
by MikeD
Ritchey Logic road. Cables are externally routed too.
TwiggyForest
by TwiggyForest
The Specialised Aethos would be up there for "best" mass manufactured bike. You could also go down the custom frame route.
DaveS
by DaveS
Does being the most expensive and/or the lightest make a frame the best? I look for the best bang for the buck. That rules out $4-5,000 frames with $4,000 wheels.
I really like my Cinelli Superstar disc bikes. Standard 27.2mm post, standard stem and bars and reasonably priced tubeless wheels. I bought two frames for $1000 each. Great paint jobs. I like the larger trail geometry. They descend like they're on rails.
openwheelracing
by openwheelracing
Not 100% but I was in same boat and ended up with Time Alpe D'Huez 21. Keeper.
uraqt
by uraqt
So this is weightweenis so yes lightest is best... teasing, however the Aethos was designed by one of the best carbon bike designeers/team around.. also it's not that much more if you just look at the frame costs. : ) Most of "us" don't need or want the factory build specs....
C
Perp
by Perp
openwheelracing wrote:Not 100% but I was in same boat and ended up with Time Alpe D'Huez 21. Keeper.
Was going to recommend the same bike
Sent from my Pixel 5 using Tapatalk
petromyzon
by petromyzon
uraqt wrote:
Mon Oct 18, 2021 11:15 pm
Second tier frame has ports for mechanical shifting so that is the one to get.
thirdsun
by thirdsun
Rose X-Lite uses pretty much standard components and is very fairly priced - here's the X-Lite Six Disc for instance: https://www.rosebikes.com/bikes/road/ra ... e-six-disc
bobones
by bobones
Lina
by Lina
bobones wrote:
Tue Oct 19, 2021 11:17 am
I would rule out disc brakes entirely on the grounds that they are not "easy to service", particularly those with hidden cable cockpits.
Disc brakes aren't any harder to service than rim brakes. Yes, they're different to service, but not harder. And cable integration making service harder has absolutely nothing to do with disc brakes. That's an issue caused by cable integration, not disc brakes. Sure, most of the bikes with full integration have disc brakes because using rim brakes with full integration would make them awful because the cable runs would be awful at best.
petromyzon
by petromyzon
Depends very much upon perspective but if you want a premium-level bike that is as forward compatible/future proof as possible your choice is disc brakes or..... disc brakes.
bobones
by bobones
Cemicar
by Cemicar
It's a bit shame Aethos sticks to 160mm rotors with the proprietary front caliper mount.
