Incorrect chain routing through rear derailleur, lug sawn half through
- musiclover
https://photos.app.goo.gl/FXyniXCic7ZQPo1q7
I could say I am an idiot. But in my defence I had to put the chain on half asleep at 0300 hours at night in the dark and then ride in the dark on a noisy road and through a thunderstorm.
Then I realised the chain did not sound right. Because I took it off upon coming home, took me a while to understand what happenned.
Anyway, the damage to the routing log and possibly chain outer links has been done.
Are their any consequences to this lack of technical culture? Does anything need replacement? Anything needs fixing? Has it happenned to anyone else?
I have retired from this forum, not wasting any more time here.
I've done it (also rush job) but noticed it right away. I would replace chain. The lug is not pretty but I'd say still functional; that I think is an optional replacement
Edit: replace chain so I'd feel comfortable. The lug I would clean up with a file and leave as is.
I've made that mistake as well and didn't realize it until the lube/wax ran thin and started to make noise. Live and learn. You would think that the pin would be replaceable...but I think it is attached to the outer plate with a small bolt, since I have seen a few outer plates with the pin detatched. The pin inbetween the two pulleys are attached to the inner plate...both can be replaced.
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
- Factor LS Disc
Never done that myself, but I did fix that problem on a bike out on the road after overhearing a young rider asking one of the leaders of his ride group why his bike was so hard to pedal, especially on the uphills about 40-miles in on a 62-mile fund raising ride .
- Michael
I have done it as well but mine was a tab on the SRAM cage on a short test ride. The tab was not holding the 2 halves of the cage together.
So, not structual at least on the SRAM. It was a guide for just incase.
Degreased and put some black paint and cleaned some metal bits but life goes on. Might have shaved 1 gram or so.
There were some shifting issues while doing this (can't shift properly to some gears)
This is just a consequence of not using a workstand to elevate the bike and be able to thread the chain properly, then spin and inspect the bike.
I think that "pin" is aluminum on yours so it wouldn't have wear the chain too much. If it is (pending magnet test) Probably just a cleaning will be good if you don't see any damage on the chain.
I don't know why but I have done it more than once, first time I caught it on the workstand due to noise. But you would think once is enough to be very careful threading the chain.
Ooh. Rough.ms6073 wrote: ↑Mon Oct 18, 2021 3:32 pmNever done that myself, but I did fix that problem on a bike out on the road after overhearing a young rider asking one of the leaders of his ride group why his bike was so hard to pedal, especially on the uphills about 40-miles in on a 62-mile fund raising ride .
Looks like bad wear to the chain links from the photos, i would replace. A snapped chain link at full noise is probably a hospital trip. I would ignore the wear to the bump stop.
PoorCyclist wrote: ↑Mon Oct 18, 2021 4:41 pmI have done it as well but mine was a tab on the SRAM cage on a short test ride. The tab was not holding the 2 halves of the cage together.
The lug prevents the cage from pinching. That's really the only thing it's there for so even the amount of damage in the OP's case is fine.
