Carbon seatpost with easiest to use saddle clamp?
- WonderSausage
I need to swap saddles easily on a bike-fit bike. What carbon seatpost has the easiest to use saddle clamp? Something that can accept 7 or 9mm rails, where the screws don't come out when swapping 9mm carbon rail saddles. Obviously no fiddly cylinder side-clamps, we used to use a Trek and that was a serious pain.
- WonderSausage
Good idea in principle, but we tried that a while back and ended up destroying a saddle by rubbing through the carbon with the bolt. The clearance looked fine with the saddle mounted, but they flex considerably with someone riding them.
