Internal cables
- Moderator
On the wyndy Milla.. it is in the build que. Currently a THM stem and Enve aero 37/42cm handlebar. This will mean external cables from handlebars to frame although I am running Etap (think TCR or Aethos)
I could go internal cables with Deda alanera or Vision 5D ACR... I would look slick but be heavier and couldn't get as narrow..
As I want to use this bike to travel to Europe would I be mad to change to internal cables?
Allegra- Steel Lugs TBC
Aurelia- Stainless All Road 8.5kg
Bertha- TT 9.8kg
Perdita- Ti Turbo bike 8kg
Serenity- Ti Gravel 9.5kg/8.9kg
Verity- Ti Aero 8.2kg
Alya- Ti Climbing TBC
Bertha- TT 9.8kg
If I was buying a bike knowing I would be flying with it a lot I'd probably steer towards external rather than internal cables. If it was just a few trips (once or twice a year) then it wouldn't be an issue for me.
- Moderator
Just a couple of times a year... just wondering if the weight and faff are worth it for the look and aero
Bertha- TT 9.8kg
Bertha- TT 9.8kg
Go for FSA's SRS headset system so you can keep the THM stem while still maintaining some semblance of cable management. See Titici's implementation to get what I'm talking about.
In my opinion, there's nothing cheaper looking that seeing a mess of cables. Makes the bike look like a homemade bomb!
- Moderator
Is this the best option for this sort of set up? Anything lighter/more Gucci?StiffWeenies wrote: ↑Sun Oct 17, 2021 6:02 pmGo for FSA's SRS headset system so you can keep the THM stem while still maintaining some semblance of cable management. See Titici's implementation to get what I'm talking about.
Bertha- TT 9.8kg
Bertha- TT 9.8kg
To my knowledge only Token's S-Box has similar functionality to FSA's SRS system. I'm not sure about lighter but it is the only way you can have clean cable routing with Gucci cockpit components like your THM stem. Also, does WyndyMilla even have a fork that supports fully integrated cockpits? All the models on their website show bikes with standard internal cable routing setups.CustomMetal wrote: ↑Sun Oct 17, 2021 7:37 pmIs this the best option for this sort of set up? Anything lighter/more Gucci?StiffWeenies wrote: ↑Sun Oct 17, 2021 6:02 pmGo for FSA's SRS headset system so you can keep the THM stem while still maintaining some semblance of cable management. See Titici's implementation to get what I'm talking about.
- Moderator
Check out their Insta from Bespoke although the bike is branded a spoon so I wonder if they are dropping the Wyndy brand?..
Bertha- TT 9.8kg
Bertha- TT 9.8kg
