I have a DM hanger for my frame that doesn't allow the same back and forth swing of the 9150 RD when it's mounted as the RD has with the stock Shimano B knuckle setup.
I am sure that it will free up over time as the RD pivots back and forth on the DM hanger but how much RD swing does the RD-9150 need to function properly? Am I risking anything by using that setup until the hanger gets polished a little and permits a bit looser swing of the RD?
DA 9150 RD & DM Hanger - Swing of RD
Sometimes just a small file can solve the issue and give freedom of movement.
IG: RhinosWorkshop
IG: RhinosWorkshop
I thought about that but never got around to trying it. I think I will now. Cheers.
I'm still curious about the movement question, though. Is that very free swing of the 9150 RD on the B knuckle integral to its functionality?
The new shadow-style RDs don't pivot at all during normal operation. Only when replacing the rear wheel.
'24 S-Works Tarmac SL8 RTP - soon™
'22 Tarmac SL7 Expert | Ultegra R8100 | Alpinist CL / Custom Rapide CLX 2x60
'19 Diverge E5 Comp
'18 Epic HT Comp Carbon WMN
'18 TCR Adv Pro 1 Disc
'19 Diverge E5 Comp
Don't really think its an issue as once the B-screw is in position...doesn't matter if it moves or not. Make sure B-screw position is correct...then tighten it down into position and you should be good.
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
- Factor LS Disc
