Anyone using Deda Superzero bars with Campagnolo?
Ive just slid a Chorus 12 speed hydro lever on Deda Superzero aero carbon bars and it looks like that having the bars at the correct angle means the lever is sloping down. The lever was as far round as it would go. Are these bars incompatible with Campag levers?
Hi, I have chorus 12 mechanical on superzero carbon.
I have the ends of the levers inline with the bottom of the drops.
They don't go up much higher than that as the bar thickens fairly quickly.
Was the same with chorus 11 levers.
In terms of the bars in the stem I have the bottom of the drops parallel to the floor.
That makes the underside of the bar flat/parallel and the top sloping down towards you. Kinda like an aeroplane wing.
Are the tops of the levers sloping down?TonyOliver83 wrote: ↑Fri Oct 15, 2021 10:15 pmHi, I have chorus 12 mechanical on superzero carbon.
The carbon Deda bars are known to have this issue where you cannot place the shifters as high as you'd like.
Related replies:
viewtopic.php?p=1634571#p1634571
viewtopic.php?p=1634736#p1634736
Related replies:
Thanks. back they go then.maxim809 wrote: ↑Fri Oct 15, 2021 11:29 pmThe carbon Deda bars are known to have this issue where you cannot place the shifters as high as you'd like.
Related replies:
Hi mate, the 12 speed ergos don't really have a 'flat' part on the hoods are quite curvy or U shaped.wilwil wrote: ↑Fri Oct 15, 2021 11:21 pmAre the tops of the levers sloping down?TonyOliver83 wrote: ↑Fri Oct 15, 2021 10:15 pmHi, I have chorus 12 mechanical on superzero carbon.
Will try and get a decent side on pic tomorrow.
I had similar issue with my SR 12 shifters and an ITM bar; I used a piece of used bad tape on each shifter and it's working perfectly since last winter.eurperg wrote: ↑Sat Oct 16, 2021 11:12 amThere is a solution, see this topic:
https://r.tapatalk.com/shareLink/topic? ... source=app
