Aftermarket Cassettes
The general all-things Road forum!
BigBoyND
by BigBoyND
What is the difference between these two listings?
https://de.aliexpress.com/item/10050076 ... pt=glo2deu
https://de.aliexpress.com/item/10050079 ... pt=glo2deu
And is this one also the same other than the color options?
They're all on Ztto's page, so I'm confused why they'd have so many listings for the gen3
JWTS
by JWTS
BigBoyND wrote:
Mon Nov 25, 2024 2:53 pm
Because Ali! Those are all the same (except for color of course). I noticed that the funny colored ones were the first that they produced, and then the others started to trickle in. Note that they also have it under the "Goldix" name just to add to the confusion. They're identical except for the lockring. I have one of each (one in an 11-36 on my wife's bike). They're 100% the same cassette.
SuecoGuatemalteco
by SuecoGuatemalteco
Got a pink Goldix today today. Crazy light as you can see. It's a 12-speed 11-30, 140 grams lighter than my current Ultegra with same ratio.
However, it doesn't "fit" my Tune Prince hub. It's apparently a tiny little bit wider than the Ultegra cassette so it rubs on the frame. I had change a lockring in the Tube hub to be able to fit the Ultegra 12-speed cassette last year.
I tried it on my simple Prime and it worked fine. So featherlight cassette on an anchor of a wheel :noidea:
I guess I'll have to buy new wheels :beerchug:
2023 Time Alpe d'Huez 2023
2020 Bianchi Oltre XR4 *Sold
2018 Giant Propel Pro Advanced
2017 Bianchi Intrepida *Sold
2016 Verenti Technique *Sold
JWTS
by JWTS
SuecoGuatemalteco wrote:
Wed Nov 27, 2024 5:43 pm
Any way to put a .5mm or 1mm spacer inboard (or even outboard) of the axle? Not familiar with those hubs, but I would think there should be a way to make this work?
SuecoGuatemalteco
JWTS wrote:
Wed Nov 27, 2024 6:11 pm
Hmmm. I'm not good at this kind of stuff. Do you know what kind or anything, could you point me in the right direction?
When I got the wheels a Shimano Ultegra 12-speed was to wide. I bought the wheels used but the seller arranged Tune to send me a new lockring, and I had it swapped. It was just a tiny bit thinner but it made the trick. So it seems like the Goldix cassette is a tiny bit wider than the Shimano which is to much for the Tune-hub.
JWTS
by JWTS
Wed Nov 27, 2024 7:05 pm
So, I'd contact Tune. Honestly, I don't know anything about these hubs, but I also know that I would probably do in this situation is simply stick a .5 or 1mm spacer at the end of the wheel and put the thru axle through it and install the wheel. Something like this: https://www.amazon.com/DEYING-Pack-spac ... B0DHJ83YRN
Maybe someone with these hubs can chime in if there's a more elegant solution, but this will work. Your frame spacing will be increased 1mm if you do this, of course. This would not bother me in the least, since the generally accepted tolerance is 1mm (+/- .5mm at most frame factories). That said, this is what I personally would do. You do you!
TidyDinosaur
by TidyDinosaur
JWTS wrote:
Wed Nov 27, 2024 11:02 pm
Untill you get a flat, forget about the washer, lose it while taking out the wheel and have the cassette rubbing when you start riding again.
SuecoGuatemalteco
No need for any washers or spacers. Check the hub again and found two spacers all the way in, camouflaged. Took them of and voila, the off topic post from can stop. :mrgreen:
JWTS
by JWTS
TidyDinosaur wrote:
Thu Nov 28, 2024 9:54 am
As I said, "that's what I'd do", because 1) I wouldn't lose the washer, and 2) I haven't removed a wheel by the side of the road since the Obama administration. I mean, I rarely carry a tube, why would I remove the wheel? If two Dynaplugs aren't going to fix it, not sure what good a tube is going to do...
Back on topic though...I have back to having a creak with the hybrid cassette. It's only on one cog, the last position steel cog. It's a big concerning because I think that's where the pins go in from the top three aluminum cogs to the steel cogs. I have to take a look at it, but wondering if anyone has experiences this w/the Gen 3 hybrid cassette? Shifting has been great, cog noise is low, but the creaking on that one cog is making me wonder about the connecting pins...
TidyDinosaur
by TidyDinosaur
JWTS wrote:
Thu Nov 28, 2024 8:40 pm
Damn, just ordered one myself... I had a creak on the ZTTO gravel cassettes I bought 3 years ago. A little oil did solve the problem. Untill the rivets gave in and I had some cogs spinning (was an XD cassette). I didn't even get to 1000km on those...
JWTS
by JWTS
TidyDinosaur wrote:
Sat Nov 30, 2024 5:43 pm
So, I did remove it to take a look. Obviously hard to see through where the pins connect, but I don't see any bending of the pins/nothing misaligned. What I do see is that the aluminum cogs have a round carrier that butts up against the steel cogs. My guess is it's just the dissimilar metal creak you occasionally get front aluminum on steel. I think spraying some Sailcoat on this would get rid of the noise, except I'm hesitant to introduce a spray lubricant into the mix with my waxed chain... Guess I could meticulously clean it off. Sailcoat tends to stay in place once it's dry.
FWIW, I'm probably going on 1,500 km on this as I'm riding a ton right now, and all is still welll outside of the creak. I still view it as a "race only" or "event only" option, but I want to be completely confident in it before riding it on a day I care about it.
If it explodes, I'll be sure to report back.
Butcher
by Butcher
Sailcoat=Sailkote just to help those that are wondering WTF is Sailcoat.
Thank God for Google.
JWTS
by JWTS
Butcher wrote:
Sat Nov 30, 2024 7:32 pm
Auto incorrect, thanks! It's a Volkswagen owner's best friend for eliminating all sorts of unwanted sounds. It seems to last much longer than other silicone sprays. It also smells terrible, so it's best to use outside if possible
Butcher
by Butcher
Good to know. I own a German auto repair shop. Mostly Mercedes, but I suspect that might just work. Do you know if it works on clients? :P
satanas
by satanas
^ You might need to submerge them in it for a while...
