Wilier zero 6 vs cervelo rca
joeenglert
by joeenglert
I know both of these aren't made anymore but you can still find some old new stock at some shops. I have a wilier zero 6 in a small size and it weighs about 960 grams for frame fork and hardware...now I think the rca weighs almost the same...I'm very curious if anyone out there has ridden both bikes and assuming they are more or less the same weight and I know the cervelo is quite a bit more expensive...how do the rides compare?? That is my question...cheers. Joe
cpac54
by cpac54
Both are great looking framesets (I just recently bought a 2015 RCA myself!) Fairly different geometries on those bikes though - which one fits you better?
I've never ridden the Wilier myself, but I believe the Wilier, whilst being in the same weight range as the RCA, is not an overly stiff frameset in comparison and has a max. recommended rider weight of 80kg. Tire clearance would be better on the Wilier vs. the RCA (room for 28s vs 25s). Both should climb like goats though by all accounts.
mnmasotto
by mnmasotto
I have owned both. The RCA is a stiifer frame. I found the Zero 6 a little too flexy in the rear end.
tabl10s
by tabl10s
mnmasotto wrote:
Sun Oct 24, 2021 10:20 pm
What made you sell the RCA.
2015 Pinarello F8: 13.13lbs/5.915kg(w/Roval 64's). Sold.
2016 Rca: 11.07lbs/5.048kg.
2015 Rca. 11.15 lbs(w/Roval CLX 32's)
2015 Rca/NOS(sold).
2018 S-Works SL6 Ultralight 12.03lbs(w/Roval CLX 50's)
mnmasotto
by mnmasotto
I still own and ride my RCA.
