PF headset cups delamination or just normal wear?
- musiclover
I have been doing a minor headset service and noticed some marks on the PF cups. They do not look like cracked or deformed, rather have some marks on them.
https://photos.app.goo.gl/FxYzY1xxaQj3VUjZ8
Should I be concerned? Is there any coating that should be used to prevent further wear? Most of that wear is probably from neglected headset services years ago where grease outside of the bearings became too contaminated and bearings too rusty.
A sidenote - for that protective coating on the outside of bearings I have gone from bearing grease (very poor) to bentonite grease (fair) and to silicone paste (don't know but hopefully even better).
I have retired from this forum, not wasting any more time here.
Hard to tell from the pictures. Just about any grease should be OK outside the bearings. Marine grease should work in the wet. The bearing seats shouldn't wear unless the headset has been run loose. A significant preload on the bearings is required to eliminate movement. It's only too much if the front wheel fails to self-center after a turn.
What's inside the steering tube?
- musiclover
I think I must have had enough preload as I also noticed the expansion plug slipping 1mm upwards. Interesting fact - regardless of the tightness of the top preload plug the handlebar still runs smoothly. Never had it so that it would stop turning freely. Maybe I need to have it even tighter? But then again, have not noticed play there.
What's inside the fork? Don't know, looks a bit messy, like some fine cobwebs inside.
This sounds as if your expander was moving upwards while you set the preload. Maybe check your expander?musiclover wrote: Interesting fact - regardless of the tightness of the top preload plug the handlebar still runs smoothly. Never had it so that it would stop turning freely.
- musiclover
Did slip the last time 1 mm upward, however, no play.Maddie wrote: ↑Fri Sep 24, 2021 5:42 amThis sounds as if your expander was moving upwards while you set the preload. Maybe check your expander?musiclover wrote: Interesting fact - regardless of the tightness of the top preload plug the handlebar still runs smoothly. Never had it so that it would stop turning freely.
This time I could not observe any slipping of the expander.
I only use the recommended expander torque setting (8 Nm).
